BIKELAND > FORUMS > ZX-14.com > Thread: zx14 clutch problem NEW TOPIC NEW POLL POST REPLY
serius blk
posted August 04, 2010 07:22 PM
zx14 clutch problem
i have hd springs and spacers. I have clutch but it gets soft after i get on it. As soon as i lower the rpms the clutch handle gets stiff as normal. I changed the seal in the slave cylinder but still having the same problem
fury
posted August 06, 2010 02:33 AM
You have air in your lines. Bleed your lines doing the following. Place a container of break fluid at the bottom of the bike with a rubber line from the nipple off the clutch housing in to the container. Open up the nut bleed. Make sure the hose is in the break fluid. Add break fluid to the top reservoir. Pump the clutch. It will get firm. Do not run out of break fluid in the top reservoir or you will introduce air to the system.
hope this helps.
0.27415990829468 seconds processing time
