BIKELAND > FORUMS > ZX-14.com > Thread: electric prob, (zx12) NEW TOPIC NEW POLL POST REPLY
kiwi12
posted August 02, 2010 01:29 AM
Ok, so ive got new battery, and had my stator rewinded,
got a secound rr just in case,,
So i install the new stator, and a second hand RR known to be good,
start bike up and at idle im getting 13.9 to 14.1
start to rev bike up to 4k and then i see the volts dropping down to 12.9
but no further than that.
so i change to another RR and same again
I unplug the lights and then rev to 4k and i get about 13.8-14,1 volits.
I then unplug the RR and the bike picks up about 500 revs.
Ive got a gear postion sensor, a rev light/battery indercator, and a in line volt meter /lap timer .
also a yoshie ems.
Also i had a problem with the clutch switch, so i bypassed this a month or so ago.
Im about to go to a shop and get a auto elctric to have a look, but was hoping some one here may have a idea
cheers
what is going on in here?
BIGZXDADDY
posted August 02, 2010 12:55 PM
have you checked for voltage drop on battery cables, grounds, etc.?
"never drive faster than you can see, besides it's all in the reflexes"
BobC
posted August 03, 2010 03:21 AM
That sounds like something is heavily loading the circuit . Especially as you say "I then unplug the RR and the bike picks up about 500 revs".
Are you sure the new battery is a good one?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
INTIMIDA2OR
RED rider!
posted August 03, 2010 02:02 PM
The voltage is not supposed to drop at higher rpms. It is supposed to peak out and stay there unless there is a severe drain on the system or the RR is still not doing it's job.
You already replaced the stator and the battery with new stuff. I reccomend you replace the RR with a brand new one and see what happens.
Also is your volt meter accurate? I had one that was acting up and read a charging system wrong just like you described .
'06 Passion Red ZX-14
*Lee*
kiwi12
posted August 03, 2010 11:21 PM
Ive used 2 volt meters, and the same reading each time..,
ill get a new RR, and check for any drain,
BIGZXDADDY
posted August 04, 2010 12:12 PM
are you taking readings from the battery only? if so you need to take readings at the generator and at the regulator. if you are seeing differences in readings check main power cables for drop (high resistance). with the engine running measure voltage between battery + and gen +. if you a get a voltage reading the battery cable has to much resistance. check all the cables and grounds that have to do with the charging system like this to determine the cause of your problem is not in the wiring or hard grounds. if all that checks ok then you have a circuit that is pulling to many amps. at that point isolate all circuits individually to find your problem
chrisdhall
posted August 05, 2010 05:37 AM
You don't say what model year the ZX12 is. The early models like the A model I owned had a poorly made connector connecting the stator to the RR. These often failed, in my case it actually melted. I've heard that some caught fire! I ended up soldering the connections. Later models had individual connectors for each stator wire. (Not that Big K would admit there was a problem with their design)
Just a thought.....
kiwi12
posted September 02, 2010 12:47 AM
Just a thought.....
Its a 03
I have put a new stator , and RR on today,
idles at 14v
but as soon as i rev ,even slightly the volts drop.
Im going to pull yhe harness and go throu it,
posted September 02, 2010 03:01 AM
before doing anything drastic use yr voltmeter and see what the voltage is immediately out of the reg whenrevving to 3-4K, then measure again at the + battery post.
I had yr exact symptons and it was simply resistance in the connector of those thick white wires in the battery case.
kiwi12
posted September 05, 2010 10:13 PM
So, i have changed the white wires around the battery and coming from the RR,
I have found that when i unplugg the lights the volts stay at 14.1.. and only drop on start up.
as soon as i plug the light back in the volts drop, as soon as i touch the throttle ,
and keep droping , to around 13,6 volts at 4000 rpm.
I have the correct bulbs,
any help would be great.
Cheers
0.23109197616577 seconds processing time
