BIKELAND > FORUMS > ZX-14.com > Thread: Stock exhaust files out map? NEW TOPIC NEW POLL POST REPLY
zoldar
posted July 26, 2010 01:27 PM
Does anyone have a Stock exhaust files out map for a PCV?
Don't have an exhaust yet but wanted to install the PCV and pull the files.
Thanks!
John
zx14fan
posted July 26, 2010 02:53 PM
Get a dyno or a map from brocks if you buy his system.the rest of the maps from pc dont work and you will leave a ton of hp on the table that way.
zoldar
posted July 27, 2010 10:43 AM
bump
LAB3
posted July 27, 2010 10:47 AM
Try a slip on map for flies out for your year model. If you have a 2006/2007 you will feel a big difference as the ECU is SLOW about opening the secondary flies. The 2008 and up have a different ECU that opens them a little faster. Go to the K&N map site, they are Ok for what you are doing. Just saw you have the Green must be a 2008.... I would wait and install a full system and then remove flies and new map for all your mods. Brocks Maps are hard to beat he really does a good job on them. His exhaust systems are hard to beat too. :-)
zoldar
posted July 27, 2010 03:27 PM
Thanks for the input. I guess I will wait till I get a pipe to pull the flies.
The Green meanie is an 09
dogg24
posted July 28, 2010 11:58 PM
Where did you get the PC from? I have one if someone can tell me how to copy it I'll send it to you.
2012 ZX14R SE, Streetmeg, PCV
0.29151606559753 seconds processing time
