BIKELAND > FORUMS > ZX-14.com > Thread: Rods with muzzy kit NEW TOPIC NEW POLL POST REPLY
06redzx14
posted July 18, 2010 04:39 PM
Rods with muzzy kit
Are stock length rods used with the muzzy stroker kit? What are the options for stock bore and 5 mil crank?
posted July 18, 2010 04:40 PM        Edited By: Shane661 on 19 Jul 2010 00:41
Yes, stock length. You lose one ring. Muzzy doesn't even list the 1534 kit anymore.
06redzx14
posted July 18, 2010 05:12 PM
Ok thanks. Now does anyone know about case clearance for the 5 mil crank? I've heard they need to be notched to allow the rods to clear
Y2KZX12R
CompetitionCNC.com
posted July 18, 2010 06:03 PM
Carrillos fit without any case cleaance issues. You will need to grind the head of one rod bolt for clutch basket clearance with a Hays clutch and other billet baskets as well.
I'm running stock length carrillos and a +5mm stroke (66mm). The pistons are custom CP two ring piston with good 18mm pins.
Y2KZX12R
CompetitionCNC.com
06redzx14
posted July 18, 2010 06:29 PM
thanks can't wait to see your 14 in action
NINJA12
posted July 19, 2010 08:54 AM
jim, care to explain why you choose stock lenght over shorter rods.
What bore pistons and what hp do you expect to make?
posted July 19, 2010 10:12 AM
Who is doing the block, and who is doing the crank?
very interested to see your progress and the outcome.
0.23798704147339 seconds processing time
