BIKELAND > FORUMS > ZX-14.com > Thread: Installing all the good stuff NEW TOPIC NEW POLL POST REPLY
youngninjadude
posted July 15, 2010 12:03 PM
About a week ago i started installing several parts and ill be posting pictures of all this
I am installing:
Brock's Street Meg ceramic coated black
Bazzaz Z-FI
Innovates DL-32 datalogger
Innovates LC-1 wideband controller
Innovates XD-16 gauge
HIDS
LEDS
GPR4 steering stabilizer
Secondary ZX14 OEM fan
Brocks radial mount bracket and strap
Lowering links
zixxer14
Damn that was Quick
posted July 15, 2010 12:26 PM
Did you win the lottery?
bad ass 14
posted July 16, 2010 03:36 AM
Lookin good bro. I think YND still lives at home and is doin exactly what I would do.
Bad ass 14
01smokes
posted July 16, 2010 03:46 AM
dang best of both worlds i see, its the only way to go lol
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
fbmbks
posted July 16, 2010 07:30 AM
I was starting to forget what they looked like unstretched
Compton
posted July 16, 2010 09:16 AM        Edited By: Compton on 16 Jul 2010 17:17
nice, the DL-32 and LC-1 were some of the best things i've installed. its nice to be able to see what you are doing!
b.w.
posted July 16, 2010 09:29 AM
+1
youngninjadude
posted July 16, 2010 10:28 AM
The secondary fan is on hold now since the OEM fan i bought off eBay wouldn't work. I pop riveted 2 mounting brackets to my radiator ( the top middle bracket is used for both fans), i couldn't weld them on since the radiator is aluminum and i don't really know anything about welding aluminum and my welder isn't set up for it. The bracket that the fan screws to i cut apart and did some swapping around so the fans would be even and not both angled to the right. Now all i need to do is order another fan install it and wire it up to my toggle and battery.
I had to put the baffle back in my exhaust since it was way to loud for street use, ill probably pull it out for drag racing and the Texas Mile.
The Bazzaz is hooked up and im still working on wiring in the datalogger.
While i have it apart i decided to take the rubber boot off the engine.
I fabricated a mount for a toggle switch and gauge. I also forgot to mention i installed a PMR killswitch.
Brock's street meg doesn't come with a o2 sensor bung already welded in, that was pretty disappointing.
I will also be installing heavy duty clutch springs since the clutch was slipping alot last time i was at the drag strip
Compton
posted July 16, 2010 10:42 AM
i see a new undertail in your future and soon.
b.w.
posted July 16, 2010 10:44 AM
What about a osr oil pan? Might be a good IDE before you bust yours and mess up all these good parts!
youngninjadude
posted July 16, 2010 10:47 AM
why would i need a new undertail? or a oil pan? haha
gilberjj
Friend of Fast
posted July 16, 2010 12:08 PM
both allow you to lower the bike even more.
posted July 16, 2010 01:02 PM
if you slam the bike the first time you do a good wheelie and come down, the oil plug will go up into the oil pan and all the oil is going to hit the rear tire. dont let us hear of you finsing out the hard way like a lot of us did.
CraigChrist
BAWLS
posted July 16, 2010 02:30 PM
or if you take it to a shop to have a tire put on it they'll bust if for you... then tell you that it was that way when you brought it in. Thanks a lot alba actionsports.
60ft-------1.42
1/8th------5.97
mph-------119
Obba
posted July 17, 2010 12:47 AM
I think he's mesin wit ya
GNice
posted July 19, 2010 01:45 PM
Nice...I'm looking forward to following your progress
68gts2
hobbies ( Beating you !!! )
posted July 20, 2010 11:22 AM
YND you need to use a relay in your 2nd fan wiring circut so the switch doesn't carry the fans amp draw,cost about 5 bucks.
Georgia14
posted July 21, 2010 10:51 AM
where can you get the low profile oilpan?
2009 ZX14 with stock everything and
waiting on the warranty to run out to
upgrade.
posted July 21, 2010 10:54 AM
the 2nd fan on my concourse makes it deal with FL heat sooo much better than my Zx14 did.
but the Zx14 still never overheated, just worked harder to stay cool.
CraigChrist
BAWLS
posted July 21, 2010 10:34 PM
you can get the low profile oil pan from Shannon Clem at osrbikes.com
60ft-------1.42
1/8th------5.97
mph-------119
LAB3
posted July 22, 2010 03:38 PM
Last year a complete fan assembly was less than $200.00 Ron Ayers.
Price one now ........over $400.00 for a Fan assembly 2007 ZX-14. Radiator is now $600.00 WTF
Glad I purchased a like new Rad and fan complete last year..... $150.00 TMD.
blackbullet76
posted July 22, 2010 10:00 PM
On my 14, I dropped it 3 inches and stretched it 7 inches for dragracing. After a few trips to the track, the undertail had a hole chewed through it. The rearend squated so much it rubbed a hole in it.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
0.23940300941467 seconds processing time
