BIKELAND > FORUMS > ZX-14.com > Thread: Clutch is notchy feeling and clicks NEW TOPIC NEW POLL POST REPLY
epd345
posted July 14, 2010 12:27 PM
recently my clutch pull in has become notchy and it makes a clicking noise when I pull it in and release it? Clutch still engages but it feels like it has lost its smoothness? Any ideas? Is there a way to adjust? Do I need to rebleed?
LAB3
posted July 14, 2010 04:36 PM        Edited By: LAB3 on 15 Jul 2010 00:38
The clicking noise could be the the push pin on the safety switch. Or the clutch lever is in a bind and is really loose, so when you pull the clutch in or out the tab on the bottom of the lever that pushs it in makes the clicking. The switch is two halfs and when depressed on a angle it makes a clicking sound. Look at the shoulder screw that holds the clutch lever in and make sure it is not loose.
This happened to my 14. drove me nuts until I looked at the pin on the switch and pulled in the clutch.......
The shoulder screw that holds the clutch on was loose. It was at night and I did not notice this until the next day. Repaced the safety switch and used a little lube on the shoulder of the screw and retightened.
Also look at the tab that pushs the switch pin in on the clutch lever and see if it is chipped.
Louis
SLVR_BLT
Chicken Strips!
posted July 14, 2010 04:40 PM
It also helps to periodically lube the king pin with a dab of grease to keep the lever action smooth.
epd345
posted July 15, 2010 03:07 AM
I removed the clutch lever and cleaned the plunger and area around it which was very dirty. Reinstalled the lever and all is good now. Thanks
Hellmutt
posted July 15, 2010 04:07 AM
Good call on that diagnosis Lab.........experience pays once again
LAB3
posted July 15, 2010 10:01 AM
Glad I was a help................................pay it foward. I have learned a lot about my 14 here.
Louis
0.21869897842407 seconds processing time
