BIKELAND > FORUMS > ZX-14.com > Thread: Map for M14 exhaust NEW TOPIC NEW POLL POST REPLY
Heavy AK
posted July 11, 2010 01:18 PM
Map for M14 exhaust
I have the 2009 model with Muzzy M14 exhaust, PCV and BMC airfilter. I have checked Powercommander.com and they only have the map for the M10.
Can the M10 map be used?
Does Muzzy have a map to send?
Anybody have a base map that I can use? I also have a DynoJet Auto tune so I should be able to run a map from a different elevation than Alaska
A little GAS is a good thing!
jlewis02
posted July 11, 2010 01:35 PM
Im running the m10 map in my 08.
Its alittle rich but it still pulls hard.
The autotune will tune the bike from what ever map is in it.I think it also changes the map every time you ride to tune for weather.
08 ZX14
1.57 60'
6.09@124
9.24@155
SWB 5400ft DA 50hp shot
LAB3
posted July 11, 2010 06:11 PM
Call Tom at Muzzy tomorrow and he will send you a M14 map for your year and mod's. Muzzy use to make a M10 that had smaller head pipes then the new M14 with a M10 silencer. Tom was super nice and mailed a cd for free. The M14 stepped head pipe system is the 3rd design for the street that Muzzy has made so I would not use the the older M10 map(small head pipes) . Do you know if the secondary butterflies are still in? A flies Out map is different. The new M10 system has a M14 head pipes and M10 silencer and that map is OK jlewis.
Heavy AK
posted July 12, 2010 01:01 AM
The flies are still in and I plan to keep them there... I've decided to pick up the Ivans TRE. What ever map he sends I can still use because the TRE and flies removal Dyno map look exactly alike.
LAB3
posted July 12, 2010 02:29 AM        Edited By: LAB3 on 12 Jul 2010 10:31
Which TRE are you getting? I have a TRE006a from Ivan for my 2007 flies out and +4 on advancer. All it does is STOP the deacell pop at 3500. My friend has a map from Ivans for his Yosh he got from Ivan.sure is smooth. It's a little rich everywhere as we compaired it to Brocks Street Smart map and my Muzzy M14 map was really close to brocks. I have a Dyno map that was made local here, it looks like the Brocks after 40% TP. Tried them all doing roll on's with 2 other 14's I ride with. From 9 to 11K RPM the Brocks,Muzzy and Dyno map made my 14 a few bike lengths quicker than Ivans but in the Ozark Mountains Ivans map was smoother down low in the Real world street rideing.So if you don't Drag race the Ivans map is Great for the street.
A little Extra gas(map) is a good SAFE thing. For the street.
0.21639013290405 seconds processing time
