BIKELAND > FORUMS > ZX-14.com > Thread: Dyno Jet Autotune NEW TOPIC NEW POLL POST REPLY
Heavy AK
posted July 09, 2010 12:21 AM
Dyno Jet Autotune
Will it negate the need to load a custom map or not? I know it tunes the bike constantly so it seems that it would override any map that you had installed.
A little GAS is a good thing!
zx14r09se
posted July 09, 2010 05:14 AM
i did start with a zero map and it dose autotune att first put up the trim att 20% hi and low and when the map is done (after lots of riding) i did put the trims at 10% hi and 5% low and the all gear is on with 1,2,3 gear at 13. afr target and 4,5,6 between 200 and 450 rpm i did put the target at 14.5 ... so now the bike kicks bad ass and is verry economical when cruzzin... but it took a wile to bilt the map you have to cruse at all rpm and speed and gears. the best thing to do is to get it dynoed and then start auto tune it will trim the bike depending the temp and barometrique pressure off every day ...
anyway i loved my autotune cuzz the bike is recked now but im rebilding it soon 09 orange and black i find a 09 se orange and black from the t-rex compagnie in quebec it have all the body fram and paper and all it is missing is the electronic and motor but my motor is good so weheeeeee
live to ride...but only on a 14
  Ignore this member    Click here to visit zx14r09se's homepage.
zx14r09se
posted July 09, 2010 05:16 AM
i meen 2000 and 4500 rpm
0.24948692321777 seconds processing time
