BIKELAND > FORUMS > ZX-14.com > Thread: New Guy NEW TOPIC NEW POLL POST REPLY
jlewis02
posted July 08, 2010 06:33 PM
New Guy
Hello im new to the site and zx14.I love it so far only put 200 miles on it so far.
Im going to dragrace it more than I did with my old bike 06 FZ! fully modded.
What sprockets do you think would be best for me?Im 154lbs in full gear.
Also where can I get some maps other than the powercomander site?The bike needs tuned but I want a better map till I can get it tuned.
08 ZX14
1.57 60'
6.09@124
9.24@155
SWB 5400ft DA 50hp shot
Dark14
posted July 08, 2010 07:01 PM
Welcome!
powercomander map support is elusive. Until you buy a Brocks performance exhaust. Both his map support and exhaust systems are as good as they get.
jlewis02
posted July 08, 2010 07:51 PM
Whats the stock settings on the forks and the rear shock?
I got it used and the preveus owner was a big guy.
08 ZX14
1.57 60'
6.09@124
9.24@155
Dark14
posted July 08, 2010 08:11 PM
Look at the top thread on the zx14 forum named "ZX14 manual and fiche - full parts PDF"
Download it and save it on your computer. It can tell you anythingyou need to know about a stock zx14
posted July 08, 2010 08:44 PM
For your weight 17/40 gears for stock wheel base ....If you take it out to 62 to 64 inches use 16/41 gears ..Call Muzzy for your map ... For drag racing set you rear shock to >.. Upper all the way in and back out 1/4 turn , set the lower adjust the same as the top .. You can leave the front fork adjusters at factory setting .. Get a strap for the front and strap it down to a 1/4 inch off the front fender .. Get a flat drain plug from Shane or get an OSR cut oil pan or you will end up coming down from a wheely and busting your oil pan ..
jlewis02
posted July 09, 2010 03:00 PM
Thanx guys
08 ZX14
1.57 60'
6.09@124
9.24@155
LAB3
posted July 09, 2010 04:44 PM
Welcome, there is a lot of Drag races on this site. I have learned a lot about my 14.
Louis
posted July 10, 2010 03:56 AM
Welcome! If you like dragracing, your at the right place.
0.22868895530701 seconds processing time
