BIKELAND > FORUMS > ZX-14.com > Thread: First Time at track! pointers??? NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted July 01, 2010 10:40 PM
Ok, first time Ive had the 14 on the track, been street racing for a while, but never had it on a actual track.... A little bit about me, im 218 suited, 63 inch wheel base, NOT strapped, NOT lowered and foot shifting....running Pro tree....I know my reaction sucked and my 60fts were killing me, im -1 +2 gearing, shinko 003.....Best times:
.7905 RE
1.62 60ft
4.25 330
6.42 1/8th @ 112.84
.7159 RE
1.65 60ft
4.29 330
6.45 1/8th @ 112.78
.8574 RE
1.67 60ft
4.31 330
6.48 @ 112.50
Times got worse, with worse being 6.61 because we were hot lapping and It stood almost 9 oclock on me so i had to let out but mph went up to 115? *shrugs" basically are they decent? I know I need seat time, but would a airshifter n lowered n strapped pick me up? where should I look? Other 14's there were running 5.90's airshifting but he had 1.61 60 fts too... was he spraying?
07 LE bolt on bike
kawboy81
Busa Eater
posted July 01, 2010 10:54 PM
Ohh and track was super sticky, At 63" it would easily stand up on me leaving, and would tote the wheel through second, am I not long enough? or is it because I wasnt lowered or strapped?
07 LE bolt on bike
SixSixoh6
posted July 02, 2010 12:51 AM
let that clutch go!!! i got the same gearing and youre not much more than me. i was cutting 1.52 60' times and running 6.1-6.2 all night that foot shifting may be killing you too!!, you need to strap and lower. this bike will not stay on the ground for anything. swb it liked to come up with just the +2 gear. and stock everything else. Ge dumped, get strapped, and let that bitch eat!!!
SixSixoh6
posted July 02, 2010 12:53 AM
plus i ran 115mph in the 1/8th with an air shifter and having too much kill time. ive ran a 6.2xxx foot shifting and a 6.1xxx air shifting. i was not spraying either time.
6.6 is what i ran swb foot shifting
kawboy81
Busa Eater
posted July 02, 2010 07:51 AM
Lmao. Everytime I even tried to snap the clutch out it would stand up on me. And I like wheelies I'm talking STAnD UP on me to where I had to let out. Also what rpm are you guys leaving at?
07 LE bolt on bike
posted July 02, 2010 08:32 AM
You really need to get the bike lowered and strapped. You can leave a lot harder. I launch between 6,000 and 6,200
1badzx12r
posted July 02, 2010 09:32 AM        Edited By: 1badzx12r on 2 Jul 2010 17:33
from what i'm told stay away from an auto-misfter
automisifter bad
kawboy81
Busa Eater
posted July 02, 2010 10:27 AM
Should I do the auto shift or push button? So dropping my links to the lowest hole and strapping it would be good? Or should I compress my spring as well?
07 LE bolt on bike
posted July 02, 2010 10:54 AM
Lowest hole in the rear ... drop the forks 3/4 inch in the trees .... strap the front end down to a 1/4 inch from the fender .. Push the damn button and forget about the auto shifter ....Call OSR and get a cut pan or at least get a flat drain plug from Shane ..
kawboy81
Busa Eater
posted July 02, 2010 11:17 AM
So going from my times are they decent for a street bike? I mean it's not set up for drag but I see it headed that way, I forgot how fun that was. Hadn't been on a track since I had my zx9r lol
07 LE bolt on bike
posted July 02, 2010 11:43 AM
Your weight and set up right you should go 5.90s @ 121 No problem .. Seat time brother seat time ...
kawboy81
Busa Eater
posted July 02, 2010 11:53 AM
Ok appreciate it bro, will drop forks strap it and lower rear, ima hit Shane up for one of them low profile plugs, could I grind off that tab as well?
07 LE bolt on bike
posted July 02, 2010 12:07 PM
Yes grind away ....
LeonidasZX14
I agree, seat time man! Keep it up and you'll get there.
09' ZX14
kawboy81
Busa Eater
posted July 02, 2010 12:33 PM
Also Keith Dennis, Aka Shine was there as well, first time seeing him in person, wow that guy is small. 5"3 lol
07 LE bolt on bike
posted July 02, 2010 07:30 PM
If your wheelying a lot, I would highly consider a pan from osr. TOO MANY guys gone down here because they didn't have the pan. A wise $125 before it cost $$$$ for new plastics and other parts, then you still got to buy a new pan when you bust yours.
c-low
posted July 05, 2010 06:24 AM
i took the muzzy pipe only,06 of mine out sat and had a best of 6.40 to worst of 6.60 buy i way only 1701 it was my 3rd time on bike first time at track that bike loves the air! im gonna 16 /43 gear it pc5 lower it front 1 1/2" on forks and last hole on links!o i do have shinko 003 and if i didnt stay in the grovve it would break out and if i did stay in it would come up have track itwould even start to rise!im also hearing about the flies and from riding my brothers 09 once and my stock 06 i can tell the sluggish in mine on lower rpms
0.42901301383972 seconds processing time
