BIKELAND > FORUMS > ZX-14.com > Thread: well its about time NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted July 01, 2010 02:49 PM
well its about time
[url]http://www.youtube.com/watch?v=XkEf8u24mOQ&feature=player_embedded[/url[
the things you learn on a busa forum
1badzx12r
posted July 01, 2010 02:50 PM
somebody can fix it please ..cause ya'll want to see this
Nelson Taylor
posted July 01, 2010 02:56 PM
I saw that over on PB.com in the ZX14 forum....... Hopefully it will generate some conversation.
If someone would elaborate on what the ECU edit does and how we can benefit from this I would appreciate it... Also as far as tuning how easy for the average rider to do?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
CajunBoyz
posted July 01, 2010 02:57 PM        Edited By: CajunBoyz on 1 Jul 2010 22:57
How about this???
1badzx12r
posted July 01, 2010 03:56 PM        Edited By: 1badzx12r on 1 Jul 2010 23:59
http://boostbysmith.com/
Some of the features include:
Ability to view all sensors data with a laptop connected
Ability to clear fault codes
Ability to change fueling maps (both IAP and TPS maps) for better, more precise tuning than piggyback systems.
Ability to change ignition maps (you can add timing in the lower gears like a TRE does without messing up your gear based fuel curves)
Increase your factory rev limiter (current software supports up to 12,500 RPM)
Remove the 6th gear speed restriction with the click of a button
Ability to dis-able soft cut limiters which can burn up your NOS or Turbo bike, hard-cut shuts all injectors down vs just a couple.
Turn your ECU into an ignition / fuel kill box for use with an air/co2 shifter. Gen 2 Busas's can utilize gear based engine kill times (different kill time for each gear)
Switch-able map selection for NOS, different turbo boost levels, fuel types etc
Import maps from other fuel tuning devices (testing phase right now)
Replace stock map sensor with GM 3 bar for boost referenced fueling for turbo bikes
Disable O2 sensor, pair valve, IAT sensor for dyno tuning purposes.
Ability to tune secondary throttle blade opening (don't remove those secondary flies you will loose hp)
NOW AVAILABLE: ECU controlled progressive gear based Nitrous/Fuel/Ignition Ramp Rate Control. www.boostbysmith.com/ecunos2.html for details.
This works on Bking as well though at the moment doesn't have as many features (B-king you can re-destrict, map fueling, increase rev limiter, use ecu as kill box, dis-able exup, canister, O2 sensor, pair valve)
BASICALLY Nelson you can take all the aftermarket gadgets off and tune everything thru the ECU .. reason 1 why i purchased a busa
Bently
2012 14r In Blue and no Mods!
posted July 01, 2010 05:14 PM
Nelson, look me up at 2wheelspeed next weekend and i can tell you anything you want to know about the ecu tuning. Mine and dennis are tuned thru the ecu. My air shifter runs thru it as well as I have a nos set up working thru it on a progressive controller right thru the ecu.
1badzx12r
posted July 01, 2010 06:32 PM
I
why to go ..busa brother .. these zx14 knuckleheads will never know whats that be like not having alot of baggage under the seat
Bently
posted July 02, 2010 03:04 AM
It is nice, no airshifter kill box, no pwr comander, no progressive nos box, I can advance timing the list goes on and on. My other buddie is just getting ready to fire his turbo bike up and the boost controller wil go thru the ecu.
Nelson Taylor
posted July 02, 2010 06:25 AM
Thanks for the info fellas,
Bently, I will come check it out.... I have been hearing things about this but no one in my area is hip to it.... Joey F. from 2wheelspeed talked to me about it for a brief minute. I asked him how in the hell did he blow bye me in 3rd gear in the 9.50 class. He said 3rd gear activated nos tuned thru the ECU.... That got me asking questions..
Best #'s
1.54
4.03
6.02 @ 121mph
posted July 02, 2010 07:33 AM
they been doin that with busas for almost 2 years now, and still just gum flapping about the zx14 ECU.
1badzx12r
posted July 02, 2010 08:15 AM
did he break out
Nelson Taylor
posted July 02, 2010 11:48 AM
did he break out
He did not break out.... He has it setup to spray only in 3rd gear for a set RPM range then it shuts off . Its setup real nice, he extended the rev limiter. He leaves out the gate real lazy also which probably helps keep him from breaking out.
dubious your right about the gum flapping on the ZX14 ecu..... I wish they would make it happen.
Best #'s
1.54
4.03
6.02 @ 121mph
1badzx12r
posted July 02, 2010 11:55 AM
thats why i purchased a busa .i'm tired of waiting ..and all the aftermarket part's never work like they suppose too.. and all the wiring
posted July 02, 2010 12:05 PM
You still here Saint Busa ? Did they kick you off the Busa site allready ?
1badzx12r
posted July 02, 2010 01:03 PM
don't be hating smokin ..and 4 your info i own 2 zx14's and a shit load of parts .. what you own 1 zx14
and its GOD BUSA
Wheelie
Old Man
posted July 02, 2010 01:25 PM
and its GOD BUSA
waiting to hear Smokin's response lol
wee
1badzx12r
posted July 02, 2010 04:39 PM
me 2 wee
kawboy81
Busa Eater
posted July 02, 2010 04:53 PM
Can you ride both of em at the same time tho? That's tha question Lol
07 LE bolt on bike
posted July 02, 2010 05:09 PM
and its GOD BUSA
I had 3 zx14s and i also have a butt load of zx14s parts ..And even better they all out ran yours ...lol...
Superman T
posted July 02, 2010 05:13 PM
well that thing looks mighty fast to me!
Nelson Taylor
posted July 02, 2010 06:37 PM
So to date no one has edited the ecu on a ZX14 aside from this guy on Youtube?
Best #'s
1.54
4.03
6.02 @ 121mph
1badzx12r
posted July 02, 2010 07:00 PM        Edited By: 1badzx12r on 3 Jul 2010 03:15
and its GOD BUSA
oh i had way more than 3 if we counting total .. no you never out ran my bike.. my zx14 has a 1/4 mile trap speed of 171mph with with a 2,2 60ft and a jockey a little bigger than you ...so your junk has not been faster maybe quicker .. but the jockey only made 2 passes ..lol . so i have no clue what it would run if it had a teasley riding it.. but i don't loan my junk to just anybody ..
posted July 02, 2010 07:26 PM
and its GOD BUSA
171mph dosent win races... Et wins races.
1badzx12r
posted July 02, 2010 07:39 PM        Edited By: 1badzx12r on 3 Jul 2010 04:15
YADA YADA YADA .. and i can piss farther than both of ya'll .. bunch of hater's ..
HERE YOU GO TOUGH GUYS come and take it ..http://www.haraces.com/ha_main.htm
there be a class for ya'll so save your pennies ..
this looks like a good 1 ..Sate Capitol Raceway, Baton Rouge LA ** Saturday Oct 9, 2010 .. all of the guys from this forum just go here and hammer it out .. and have an all time great zx14 champ ..
posted July 03, 2010 03:48 AM
That's not being a hater, that's simple facts.
0.31473994255066 seconds processing time
