BIKELAND > FORUMS > ZX-14.com > Thread: Kleanair removal on a zx14 09 NEW TOPIC NEW POLL POST REPLY
zx14r09se
posted June 24, 2010 05:34 PM
i try to read on that but not mutch to learn about it
what would be the benifit of taking it out
and dose anyone have the way step by step to remove it
what do i do with the crank case vent
i did it on my 12r is it the same
i think (not sure) that ther is wires on the valve
is it gonna stop the pop on decel (it didint on the 12r)
My set up is muzzy m14 old stile carbon ,pcv and autotune,quickshifter,bikemaster air filter
live to ride...but only on a 14
  Ignore this member    Click here to visit zx14r09se's homepage.
zx14r09se
posted June 24, 2010 06:17 PM
ho and flies out
dcjens
Wet side of Washington
posted June 24, 2010 08:16 PM
the TRE 006A is what kills the pop if your interested..or stock exhaust :o
Black 06
dcjens
posted June 24, 2010 08:17 PM
ho and flies out
What is a fly?
Black 06
LAB3
posted June 25, 2010 10:24 AM
What is a TRE?
zx14r09se
posted June 25, 2010 01:09 PM
is that the ivans tre????
LAB3
posted June 25, 2010 01:42 PM
yes being a wise azz.... there are several models my 2007 is for flies removed........this one keeps the ECU in a non smog map (always shows N on gear changer) it is for elimteing the deacell pop that you hear
when you install a non stock exhaust. The 2008 model opens the flies sooner than stock and no pop. Take care in which one you choose. Brock sells them too.
0.23907589912415 seconds processing time
