BIKELAND > FORUMS > ZX-14.com > Thread: Anyone using the MSD SB6??? NEW TOPIC NEW POLL POST REPLY
Stu64
posted June 07, 2010 03:26 AM
Hey guys, went to the track yesterday and thought everything was hooked up correctly,but it seemed that the MSD was interfearing with my shift kill(separate from the MSD.
Could this be possible?
I'am not using the MSD shift kill because i already have a mps kill box.
Also my shift light is separate from the MSD as well, this week i will rewire them all using the MSD and hope for the best.
Needless to say after 4 passes i gave up and went home.
CajunBoyz
posted June 07, 2010 04:28 AM
Is that a auto shift MSD kill box???
Stu64
posted June 07, 2010 04:38 AM
No just a standard kill box.
CajunBoyz
posted June 07, 2010 04:41 AM
Did U have some timing in the SB6 box??
06redzx14
posted June 07, 2010 06:01 AM
there has been a post about this on psychobike. check there under the msd section
Compton
posted June 07, 2010 10:28 AM
a lot of times kill boxes don't work with aftermarket ignition boxes. I know every bike i've seen with an ignition module installed had to use the shifter kill through the power commander to get it to work right. I'd assume the same with the Sb6 and you'll have to use that shifter kill.
b.w.
0.28585505485535 seconds processing time
