BIKELAND > FORUMS > ZX-14.com > Thread: Manually Adjusting the PCIII NEW TOPIC NEW POLL POST REPLY
LeonidasZX14
posted June 05, 2010 09:53 AM
I checked in thier website and found no info. My question is how do you manually adjust fuel on the PC? Lee, I know you showed me once but I forgot how.....sorry. When you manully adjust it I assume that it adjusts the fuel either based on the currrent map that is loaded? Any help would be great.
09' ZX14
posted June 05, 2010 10:31 AM        Edited By: smokinZX14 on 5 Jun 2010 18:31
Press all three buttons at one time with Ign off .. Hold down all three and start bike .. Bar on the P/C will read in the middle of you did it right .Release buttons when you see this .... Now press the button in what ever range you want to change ... Up is fatter , down is leaner ... Middle is with two bars lighting up is stock ..... The changes will be made to what ever map you have install at the time .. If you are spraying a 30 or 40 shot put the high side up all the way to the top and that will give you 12% extra fuel on the top 3/4 of the map ..
LeonidasZX14
posted June 05, 2010 10:48 AM
Thanks Lee
09' ZX14
posted June 05, 2010 10:59 AM
Welcome ..
dakota9498
posted June 06, 2010 08:08 AM
Thanks Smokin, I was actually wondering about how to setup the PCIII for a 30 or 40 shot.
2008 ZX14
posted June 06, 2010 08:34 AM        Edited By: smokinZX14 on 6 Jun 2010 16:35
Make sure you run 93 or better fuel when spraying ..Don't hit the spray unless you are above 3/4 throttle ..
dakota9498
posted June 06, 2010 08:43 AM
I am about to transfer to Virginia, so I will probably do this mod this winter. Out here in Cali all you can get is 91 octane. Were you just using a button to activate it? I was thinking about a WOT switch.
2008 ZX14
posted June 06, 2010 03:09 PM
I had a WOT switch on the throttle bodys ..
0.20834302902222 seconds processing time
