BIKELAND > FORUMS > ZX-14.com > Thread: Cycle Logic Lock Up Clutch???? NEW TOPIC NEW POLL POST REPLY
indynic
Lil Show, Lil Go
posted June 01, 2010 08:23 PM
Here is the link: http://www.cycle-logicmotorsports.com/index.php?main_page=product_info&products_id=56
I have an 06 with exhaust, PCIII, BMC RaceFilter, 40 shot dry, Brock spring spacers.
My questions are:
Does anybody have any experience with this lock up clutch?
With my mods is it worth it?
Did you make any more horsepower/ improve ET/MPH?
Any Pros/Cons?
Any help would be greatly appreciated before I go (possibly) wasting my money.
LeonidasZX14
posted June 02, 2010 03:06 AM
It is possible that you improve your et's with it. It should help you 60ft more consistantly. I would highly recommend it.
09' ZX14
kawasakijockey
posted June 02, 2010 04:26 AM
Definately worth having since I have over 410 passes on the clutch where I would get 100 to 150 before.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
ninjaboy311
posted June 02, 2010 04:47 AM
Well over 1000 passes so far with mine with no issues. It definitely extends clutch life for sure. And you ride your bike the same way, you really won't even know its in there.
kawasakijockey
posted June 02, 2010 04:52 AM
Wow! 1000 passes. I would like to know the stack height on that set now. Mine is down to 2.080 last I measured.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted June 02, 2010 08:29 AM
Did any of you guys get your pressure plates modified? Have you heard anything about the lock up breaking stock pressure plates?
kawasakijockey
posted June 02, 2010 09:10 AM
No, and I have put a lot of weight on it at one time or another too. It just wears a divot where the arm presses against it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
ninjaboy311
posted June 02, 2010 10:41 AM
Sorry, what I meant to say was 1000 passes on the lock-up itself, not 1000 passes on the clutch plates.
I did get 500 passes out of a set though.
gilberjj
Friend of Fast
posted June 02, 2010 01:02 PM
500 is the most I've ever heard of out of a single clutch pack.
kawasakijockey
posted June 02, 2010 01:16 PM
I was going to drill and tap 4mm bolt holes in the center of the divots and install 4mm hex head bolts to act as buttons. Just havent gotten around to it yet but it will eventually happen.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
LeonidasZX14
posted June 02, 2010 01:18 PM
MTC does it for $70.00. They countersink nickel size pieces of steel into the pressure plat and grind down the ridges all the way to the center of the plate.
09' ZX14
kawasakijockey
posted June 02, 2010 01:22 PM
That is why I didnt have them do it. Seems like it would weaken it some. I'm going to flatten the ridges only where the bolt heads will be.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
LeonidasZX14
posted June 02, 2010 01:32 PM
What are you going to use to secure the bolts?
09' ZX14
kawasakijockey
posted June 02, 2010 01:36 PM
The plate is thick enough to tap enough threads in and red loctite will make sure they stay there. They will have to be shortened enough to just make it through the plate. Any longer and the bolts will hit the inner hub.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
indynic
Lil Show, Lil Go
posted June 05, 2010 06:45 AM
Though my thread kinda got jacked, I appreciate the feedback! Thanks
kawasakijockey
posted June 05, 2010 07:00 AM
Sorry about the threadjack. It is worth the money and bolts in without any mods to anything. The spacer is 1/2" thick and the bodywork needs no mods to fit either. You cant feel the difference in your hand when clutching for the first 40 feet. It starts taking over at about that point but you can still override it with the lever.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
indynic
Lil Show, Lil Go
posted June 06, 2010 05:37 PM
OK I bought it. Now a few questions.....
Should I still use the Brock's spacers? I only have three in right now and really can"t tell a difference from stock. I am a pretty heavy dude @ 230lbs unsuited. Should I use all five?
indynic
Lil Show, Lil Go
posted June 07, 2010 01:54 PM
Can anybody help me out with my questions?
kawasakijockey
posted June 07, 2010 02:33 PM
with the lockup installed you dont have to use any of the spacers because the lockup will apply plenty of pressure.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
BLK ICE
posted June 08, 2010 10:22 AM        Edited By: BLK ICE on 8 Jun 2010 18:25
Spacers add static pressure which helps the bike get moving and the lockup adds dynamic pressure as wheel speed increases. I personaly use the spacer, however, I am 300lb.
Kawasakijockey is the best at tuning these clutches that I have talked to. However, gearing, hp, riding style etc... all have to be consider. Long story short.... others with set-ups close to yours can only get you close. Then, try diffrent combos to see what works for you. My 2cents
posted June 08, 2010 10:25 AM
I tried it without spacers and felt it was too weak on the initial hit, which is very critical in order to get the bike moving.
If 3 spacers feel too weak to you, use all 5.
BLK ICE
posted June 08, 2010 10:28 AM        Edited By: BLK ICE on 8 Jun 2010 18:28
ninjaboy311
posted June 08, 2010 07:37 PM
I have all 5 brocks heavy springs, no spacers, with the Cycle Logics lockup. Works like a champ!
fbmbks
posted June 09, 2010 08:01 AM
ive been using mine with just stiff springs but am considering using the spacers, just to give them a try
indynic
Lil Show, Lil Go
posted June 09, 2010 04:51 PM
Guys I really appreciate all the input! I will let you know how it goes!
0.22801995277405 seconds processing time
