BIKELAND > FORUMS > ZX-14.com > Thread: Power Command V NEW TOPIC NEW POLL POST REPLY
bykw2
posted May 20, 2010 03:53 PM
Power Command V
I have a 2008 ZX-14 with a Brock short Meg exhaust, with a power commander V with a Brock street map installed. While riding the bike and the temperture increases the bike just shuts off with out giving any indication on the dash, also sometime the bike just jerk and sputters and shuts off. I have to wait for the bike to cool off before i can it restarteed seems like my fuel is getting turn off. Can this a Power commander problem or something else?
posted May 20, 2010 03:58 PM
Where is your P/C grounded ?
bykw2
posted May 20, 2010 04:04 PM
I don't know yet i will check tomorrow and see, i did not install it.
posted May 20, 2010 04:15 PM
If it's bolted to the coolant tank that maybe your problem ...Move it to the upper bolt of the alt cover ...
posted May 20, 2010 06:56 PM
+1
bykw2
posted May 27, 2010 07:59 PM
I think i fixed the problem, I found the ground wire mount to a brace coming from the frame. I moved it down to a screw on the stator cover as recommended by Dynojet. Seems like the problem is fixed. Before I moved the wire the bike would not even run. Now the bike runs just fine.
Thanks to all of you who offered good recommendations.
0.22927904129028 seconds processing time
