BIKELAND > FORUMS > ZX-14.com > Thread: Advancing Cams for more low & midrange NEW TOPIC NEW POLL POST REPLY
Acat
posted May 18, 2010 10:04 AM
Would it be possible to advance the cams? Any ideas on how to do it? I ride two up and could use more torque.
Hellmutt
posted May 18, 2010 10:23 AM
Pretty sure there's timing advance kits available aftermarket.........others here have talked about them. Personally, my 14 isn't equipped with it........but, I had the cams degreed on my 97 Yamaha track bike years ago, but it had fixed timing so was basically my only option at the time.......your best bet for better low/mid is to go with an aftermarket exhaust and add a power commander just before you pull the 2ndary flies! Then your passenger will need a harness to hang on to you
posted May 18, 2010 12:32 PM
You could move them to 102 102 and may pick up some mid range . Becarefull to ckeck PTV clearance in the intake because that will move intake valve closer the piston.. It will also spike compression at a lower rpm and you may need 93 octane so not to have spark knock ..
jetskidave
posted May 18, 2010 01:47 PM
Install a 16 tooth front sprocket from a Kawasaki Zypher from your dealer.
It will make a big diffference and cost is minimal.
Dave
2014 ZX14R Flat Black
Akrapovic 4 into 1 exhaust CNC Performance high performance street motor stock bore 14 to 1 CP pistons
CNC ported head, Cams, 48mm Bored throttle bodies, complete blueprinted engine,
10 Over Adams arm, GPR stabilizer, air shifter, quickshifter Guhl reflash ECU with duel maps installed in the ECU.
243hp, 302 hp on Nitrous progessive controller. BST carbon rims
  Ignore this member    Click here to visit jetskidave's homepage.
LAB3
posted May 18, 2010 05:35 PM
Dave
+1 You will be happy. Slotting cam gears and changing lob centers is a PIA. That only
someoe with experience should try.
SixSixoh6
posted May 18, 2010 05:44 PM
-1 +2 sprockets...mmmm tasty!
0.32317113876343 seconds processing time
