BIKELAND > FORUMS > ZX-14.com > Thread: well ladies, got a tune for the e85 trbo bike NEW TOPIC NEW POLL POST REPLY
01smokes
posted May 12, 2010 11:10 PM
i got a tune and some power numbers for the bike it made 329hp on 12psi ill post the dyno sheet tomorrow, still stock motor with 15k on the ticker
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
XLR8S
posted May 13, 2010 02:49 AM
Nice!!
ZX14, 1 piece at a time............. Roger
wrongway
posted May 13, 2010 03:24 AM
what size injector did you have to use for that ?
Are you pushing the stock motor setup , or is E85 just making more power safely ?
Roy
oilfieldtrash
Kawasaki enthusiast
posted May 13, 2010 04:56 AM
That's insane. What's it like riding something like that?
'07 white S.E. ZX-14 sold
boostphreak
posted May 13, 2010 06:12 AM
whatever you do shift early and stay off the rev limiter. the factory limiter kills the fuel not the spark. who mapped the bike? and also what turbo system are you running? thanks
gilberjj
Friend of Fast
posted May 13, 2010 06:57 AM
wow...... that's the most I've ever seen/heard of on a stock motor. Keep us updated. That must be CRAZY power.
01smokes
posted May 13, 2010 07:54 AM        Edited By: 01smokes on 13 May 2010 16:03
The fues system, its running 725cc injectors at 43psi fuel pressure, I'm not sure if it picked up more power on e85 over gas I never have ran gas in this bike on boost.
This shop called SOLID TECH here in new mexico tuned it he has been tuning for about 20 years now mostly cars, like really fast cars that get driven on the street and they last,
What was the correction factor, uncorrected hp?
johnbull
posted May 13, 2010 10:05 AM
Nice. those are good numbers. You running stock compression? How much timing have you pulled?
Keep up the good work.
John Bul Racing. Malta.
01smokes
posted May 13, 2010 10:16 AM
. Its still on a 100% stock motor and stock timing I never pulled any timing
And Shane I think the actuel numbers were right at 271hp but that was a correction for NA FI has right at a 8% loss up here
01smokes
posted May 13, 2010 10:42 AM
Oh and I was at 95% duty on the 725cc injectors at 43 psi
gilberjj
Friend of Fast
posted May 13, 2010 11:09 AM
That is a VERY happy correction
oilfieldtrash
Kawasaki enthusiast
posted May 13, 2010 11:18 AM        Edited By: oilfieldtrash on 13 May 2010 19:36
Nvm
1badzx12r
posted May 13, 2010 11:19 AM        Edited By: 1badzx12r on 13 May 2010 19:20
LAST TIME my bike was on a dyno 289hp@9lbs of boost on AVGAS -4 degree of timing
250hp @5lbs same day . i want e85 but i don't want to buy new injectors .
but since my last mis-hap all i run is C16 sometimes mixed 50/50 with avgas
01smokes
posted May 13, 2010 11:21 AM
the DA yesterday was like 8100' lol the bike will make over 300HP still on a dyno at sea levle
wrongway
posted May 13, 2010 01:54 PM
you may get more oxygen at sea level but if your injectors are at 95% you may not be able to get enough fuel in there to make much more hp.
But still impressive numbers...
Roy
posted May 13, 2010 03:00 PM
Yes, very impressive. Keep an eye on intake temperatures. Even if your afr is good, the inlet temps can cause excessive combustion temps.
01smokes
posted May 13, 2010 03:14 PM
Roy
I have plenty of fuel left I was only at 43 psi of pressure I could crank it up to 70 if needed lol
wrongway
posted May 13, 2010 05:26 PM
bumping the pressure upto to 70 psi didnt double the fuel on my bike , but there was an increase. If you get the duty cycle back to 80% you may not have as much as you think.
Roy
01smokes
posted May 13, 2010 07:49 PM
Roy
were you out of fuel line? You might have been
johnbull
posted May 13, 2010 11:49 PM
As someone already mentioned, be very carefull to try not hit the rev limiter especially since you are all stock components.
Also, if you are not running an intercooler or water injection be sure to let it cool down well between runs due to extreeme combustion chamber temperatures.
Must be a blast to ride!
wrongway
posted May 14, 2010 04:24 AM
no , when i went to a larger injector the fuel made a huge adjustment. Now I can get the afr way down in the 10's with stock pressure on the 660 cc injectors. the 440's at 73 psi were maxed out.
It just seems that pressure isnt the best way to get more fuel. Maybe it was because i used more pressure on the stock injectors? I did see that the Schnitz site says
" flow will be increased by approximately 50% at 100psi" on the 725 cc injectors
so it is not linear. Going from 42 psi to 100 psi only increases flow 50%, going up to 70 psi would be something less .
Roy
boostphreak
posted May 14, 2010 04:51 AM
what kind of regulater are you running?
wrongway
posted May 14, 2010 05:35 AM
not sure if you are asking me or 01...
I modified the regulator in the stock pump. I am back to stock pressure now with the 660 cc injectors.
Roy
01smokes
posted May 14, 2010 07:09 AM
I'm on a aeromotive 1:1 raising rate
0.25966095924377 seconds processing time
