BIKELAND > FORUMS > ZX-14.com > Thread: Heading To the DYNO tomorrow NEW TOPIC NEW POLL POST REPLY
osr
posted May 11, 2010 07:43 PM
getting up early and heading to schnitz to get the new bike on the dyno -- would like to see 200 HP on motor == going to build 2 maps - a motor map and a 75 shot map.
will post numbers tomorrow!
redxtcy
posted May 11, 2010 07:51 PM
cool! lets us know what happens!
INTIMIDA2OR
RED rider!
posted May 11, 2010 07:55 PM
'06 Passion Red ZX-14
*Lee*
CajunBoyz
posted May 12, 2010 04:57 AM
yes Enquiring minds want to know..
Quarter Pounder
with Cheese
posted May 12, 2010 01:01 PM
well.........
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
gilberjj
Friend of Fast
posted May 12, 2010 01:03 PM
well.........
+1
08green
posted May 12, 2010 03:41 PM
+2
2004 ZX10
2008 ZX14
osr
posted May 12, 2010 04:52 PM
well we were looking for 200 or more on motor -- well we didn't get it -- we didn't get close --
some info on the bike.
THis motor was in my top gas car tire bike -- its basically stock bore / stroke/ cams -- it has our port work and +1mm valves with JE nos pistons - pulled it out when I sold my chassis -- we went through the motor mid last season when we had a few minor problems -- then we pulled hte head on it and did a little more porting then droppped the pan -- all was good so back together it went and into the streetbike.
Well it ran the first night out great -- 5.90 @119 with me tipping the scales at 245 so I though it was good for the first time out.
The next night out it slowed and slowed then the battery went dead so I figured it was due to voltage and junk battery.
the following weeks I installed a tail section, a new battery and wired in some NOS and on to the DYNO
1st pull after warming the bike up -- it sounded great but only made 135 HP -- wtf ? we did it again -- same thing-- --- we checked ignition rotor and a few other things -- then went to fire it back up -- dead! battery was dead again -- so we check wires, voltage etc.. charge it up - at idle 14.5 volts -- great lets do it. --- -then it got worse-- less HP and then the tire started jumping real bad on decel -- ryan thought it was weird we tried another pull and then when he let off the thottle it died --- we all sat dumbfounded and then turned the key on and starter wouldn't do anything -- we loaded up and drove home.
got to the shop and after the ride figured something was binding the motor down maybe tranny bearing? NOPE - we pulled it apart -- #2 #3 #4 RODS and bearings were trashed , #` rodbearings were on the way out. 2 3 and 4 rods were black and looked like they were very close to breaking -- we got it off before anymore damage happened as the cylinder, pistons, head/valves were all good.
Man that sucks!! I wil post some carnage pics tomorrow.
posted May 12, 2010 05:47 PM
Shannon that sucks. When y'all took motor apart did you guys check them?
posted May 12, 2010 06:43 PM
man-o-man that sucks ...
osr
posted May 13, 2010 05:39 AM
yeah we checked them everytime and they always looked good -- we didn't make that many runs (under 15 probably) when we pulled it to sell the chassis so we only looked in the pan for gremlins but oil looked good so we just put it back as is.
Not sure if this is a problem that just popped up or was just slowly getting worse from all the BS with the dragbike not running -- we found out it had a bad coil after all the headaches so maybe it was firing at the wrong time and everything was out of sync -- the 5.90 pass was actually my first all out pass on this motor in 2 years maybe that was just enough to eat them up but we are not 100% sure --- I also started running Motul 300V in it this year -- so not sure if that had anything to do with it. We are cleaning things up today and will do some inspecting and hopefully we will find somehting
thutch26
thutch26
posted May 14, 2010 12:38 AM
Hey Shannon i have a set of stock rods... lmk not sure what their worth.....
Y2KZX12R
CompetitionCNC.com
posted May 14, 2010 04:17 AM
I have a set of factory rods and pistons..... email me if you are interested... Jim02ss@yahoo.com
Y2KZX12R
CompetitionCNC.com
osr
posted May 14, 2010 06:10 AM
thanks guys - i had a spare crank and rods on the shelf so just going to ring it and a new cam chain before we put it back together should have it back in teh bike next week.
0.23353099822998 seconds processing time
