BIKELAND > FORUMS > ZX-14.com > Thread: 5a Batt. + clock problem NEW TOPIC NEW POLL POST REPLY
Acat
posted May 04, 2010 06:36 PM
Bike cranks a little weak even @ 60 degrees ambient. Why is the clock always several hours slow every day despite reset? Is this an indicator of something?
zixxer14
Damn that was Quick
posted May 04, 2010 08:07 PM
Sounds like your battery is taking a dump.
68gts2
hobbies ( Beating you !!! )
posted May 05, 2010 03:52 AM
.......+1........
SixSixoh6
posted May 05, 2010 12:44 PM
i would chime in on this, but someone will get pissed with me again.
below 70 degrees you almost HAVE to do the "warm" procedure with them.
68gts2
posted May 05, 2010 03:51 PM
No one will get pissed,but up to this point there has been NO reason for you to plug big Brock yet. : )
russ8526
posted May 05, 2010 04:25 PM
i had a problem similar to that and it turn out to be the battery cable was slowly coming aloose
2007 zx-14 Limited
Brocks Alien Head
BMC Race Filter
PClll w / Track Map
Flies Removed
16 T Front Sprocket
Speedohealer
Fender Eliminator
0.32691788673401 seconds processing time
