BIKELAND > FORUMS > ZX-14.com > Thread: chain tensioner NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted April 28, 2010 05:45 PM
chain tensioner
Im having trouble understanding the serv manual on resetting the tensioner
speedgene
posted April 28, 2010 09:23 PM        Edited By: speedgene on 29 Apr 2010 05:28
Pg. 5-15:
Top photo is installed like the bottom photo's direction = Install UP.
2nd photo shows B as the stopper clip like a mousetrap cheeze tray and hook. You need to squeeze A like pinch both sides and raise the B clip so the rod can slide in. Shove D all the way in the cage till you hit C and stop. Release the squeeze on B. Do this as All in one movement say.
3rd photo down, you take that long flat blade screwdriver, and press down on rod A. Out she pops.
So, before you install it, practice popping out the shaft, she is not going anywhere but stay in the cage. Slide the cage in the head and hold it there. Practice where you need to tap it like a mousetrap. Make sure that flat blade extends down there to trigger the rod. The cage should push housing away from the head if you set the rod off. But...
... Once you hand trigger the tensioner, you'll be an 'ol pro, shove it in and pop it off like nothing.
E-tard
3000psi and falling
posted April 28, 2010 09:28 PM
Got it thanks!
blackbullet76
posted April 29, 2010 04:40 AM
The manual tensioner is a good investment in my opinion
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
0.24734401702881 seconds processing time
