BIKELAND > FORUMS > ZX-14.com > Thread: clutch slippage NEW TOPIC NEW POLL POST REPLY
mew
posted April 25, 2010 12:31 PM
clutch slippage
I just bought a wrecked ZX14 with 500miles. It rode fine on the test ride, but after I got it home n took it for a ride the clutch started slipping when you give it alot of throttle. Do you think i need clutch plates , clutch kit , or could it be switch or something where it has been wrecked.
zxbob
posted April 25, 2010 12:46 PM
With only 500 miles i would'nt think it would need anything -
but if your gonna do anything, throw some springs in it !
Bob
INTIMIDA2OR
RED rider!
posted April 25, 2010 12:53 PM
You need to order a clutch kit cause the clutch is shot.
EBC or OEM will be fine.
You may only need the friction plates but if the clutch is really worn you will need the steel plates too.
But the only way to find out is to inspect your clutch plates and check the steels for any warping or glazing or any other damage.
Lay the steels on piece of glass to check the straigness of the steel plates .
'06 Passion Red ZX-14
*Lee*
INTIMIDA2OR
RED rider!
posted April 25, 2010 12:58 PM
Does the clutch lever have any freeplay in it?
It should have a bit of freeplay before it engages the clutch. If not there is something binding up somewhere or something is out of wack.
*Lee*
mew
posted April 25, 2010 01:30 PM
Yea, I figured I was going to have to take apart, just wanted to see if anyone knew something minor that could be wrong. Wishful thinking. I was surprised the clutch was bad with only 500 miles.
Also, I was thinking about buying a body kit from Yes2 Yeah, anybody familiar with them. Also need tank, n headlight assembly.
posted April 25, 2010 01:33 PM
Perhaps fluid leaked out of the master cylinder or slave. I doubt the clutch is shot at 500 miles.
LAB3
posted April 26, 2010 04:01 AM
Ditto, 500 miles, look at rear tire. Bleed system first and check slave for cracks in castings or master from wreck.
Hellmutt
posted April 26, 2010 07:32 AM
I 3rd that motion.........probably some air in the line or bad component
INTIMIDA2OR
RED rider!
posted April 26, 2010 01:52 PM
Keep us updated.
*Lee*
Flame On
Fuel Air & Spark
posted April 26, 2010 02:25 PM
No doubt unless that's 500 drag racing or squid mile. There should be plenty of meat on those plates check before you buy.
77 RD 400
80 GS1000 GT
06 ZX14
reypac24
Old Fart!
posted April 26, 2010 02:31 PM
I don't think a fluid leak or air in the line would make a clutch slip, it would make it stick. Perhaps the accident caused the clutches to get soaked with oil?
Rey
Red 2006 ZX-14: Green 2000 ZRX-1100; Blue 1977 KZ-1000 LTD;
SLVR_BLT
Chicken Strips!
posted April 26, 2010 07:40 PM
Is the clutch lever bent or something? Make sure there isn't any preload on the clutch.
LAB3
posted April 27, 2010 02:23 PM
Rey
You are kidding right?? The ZX-14 clutch is soaked in oil. Every clutch I install I soak in fresh clean oil before install. Look at master cylinder piston and look at clutch lever. Take
piston out of bore of clutch master cylinder on handle bar and see if Both fluid holes are open. If piston does not move a full stroke Both ways this too will make the clutch slip.
Some Itallian motorcycles have a Dry clutch but not any Kawasaki I ever installed a clutch in.
bet you were thinking a car standard trans.
Louis
mew
posted April 27, 2010 04:48 PM
Thanks for all the input. I did bleed the clutch n took it for a 30 minute test ride n it seem to work fine. I'll take it for a longer test ride this weekend to make sure, but I cant believe air in the line let it slip like that. The lever was alot harder to pull in before the bleed though. I'll post some pictures when I get bike together.
Thanks again, Mike
INTIMIDA2OR
RED rider!
posted April 27, 2010 05:05 PM
Thanks again, Mike
Air in any hydraulic system will cause all sorts of problems.
Good to hear that's all that was wrong with your system
*Lee*
INTIMIDA2OR
RED rider!
posted April 27, 2010 05:40 PM
Rey
Louis
What's a Wet Clutch?
*Lee*
LAB3
posted April 27, 2010 05:48 PM
Wheelie still does not knowwhat a TRE is...........sigh
Rookies. :-)
0.31137895584106 seconds processing time
