BIKELAND > FORUMS > ZX-14.com > Thread: Gearing Question NEW TOPIC NEW POLL POST REPLY
epd345
posted April 21, 2010 06:30 PM
Gearing Question
Anyone ever try running 17/40? Good or bad results?
SLVR_BLT
Chicken Strips!
posted April 21, 2010 06:34 PM
1 tooth taller then stock? You cruise freeways alot?
epd345
posted April 21, 2010 06:41 PM
No, wondering if it would make the launch in first gear easier.
SLVR_BLT
Chicken Strips!
posted April 21, 2010 06:45 PM
It might, -1 tooth rear shouldnt really bog it much if at all either. Im no dragger tho.
epd345
posted April 21, 2010 06:49 PM
I might try it...sprockets are cheap
dcjens
Wet side of Washington
posted April 21, 2010 06:59 PM
I have 17-40. not much of a change really. I ride open areas, long solo. I'm not sure how much the speedo healer is off. a temporary change I'm sure.
Black 06
zixxer14
Damn that was Quick
posted April 21, 2010 07:18 PM
17/40 should put your speedo almost spot on.
posted April 21, 2010 07:19 PM
I use 17/40 for drag racing at stock wheel base .. Works great for me ..
posted April 22, 2010 02:28 AM
How much do you weigh? Is your bike extended?
68gts2
hobbies ( Beating you !!! )
posted April 22, 2010 04:01 AM
Epd when you say launch do you mean at the track or just taking off in first on the street? If for the street I went with a 43 tooth rear and it makes take off so much smoother because you don't have to slip the cluch nearly as much as stock sprocket,but its still great on the highway.
epd345
posted April 22, 2010 04:16 AM
SWB and I weigh about 325
posted April 22, 2010 05:04 AM
You will hear different opinions, but if your going to the track, I think your going the wrong way in gearing. A 43 or 44 rear would suit you better. Or -1 front.
epd345
posted April 22, 2010 05:28 AM
No track yet, just thought I would try it on the street
68gts2
posted April 22, 2010 07:38 AM
For the street it depends on where you ride. If you just want to be quick around town then I would drop 1 on the front and a couple on the back,but it will suck riding on the freeway. I am 225 with 17 43 and it is a huge improvement everywhere over stock.
epd345
posted April 25, 2010 07:02 PM
I ordered the 40T, figured I would give it a go. Might improve speedo accuracy also........
posted April 25, 2010 07:45 PM
One tooth on the rear isn't going to make a great deal of difference, but it's going to make it a little slower leaving from redlights and stop signs.
LAB3
posted April 26, 2010 03:27 AM
17/43 on stock chain that has stretched out is a Great street gearing. Still run 180 and roll om's in 6th at 70 I Much quicker. I am 6'3" 240 geared up. Made a Big difference styaing even with several members I have rolled on with at 60 in2nd gear and shifting a few times.
Or on open Hiway 75in 6th and hit to pass traffic pulls like 5th with 17/40 gearing.
0.43260908126831 seconds processing time
