BIKELAND > FORUMS > ZX-14.com > Thread: Taller 1st gear?? NEW TOPIC NEW POLL POST REPLY
johnbull
posted April 21, 2010 07:44 AM
Taller 1st gear??
Does anybody know if someone manufacturers a taller 1st gear for the ZX14?? We use the engine in a car and we require a nice long 1st gear instead of the short oem 1st gear which isnt ideal for us at all.
We had a ZX12 motor in a car previously and that had a much better 1st gear ratio which was nice and long.
Any suggestions?
John Bul Racing. Malta.
Hellmutt
posted April 21, 2010 07:56 AM        Edited By: Hellmutt on 21 Apr 2010 15:56
Have never heard of anything like that -- Wonder if there's a way to remove 1st gear and space it back out to accept starting in 2nd?
salsa1
posted April 21, 2010 08:20 AM        Edited By: salsa1 on 21 Apr 2010 16:20
A larger front sprocket will give you a longer first gear...if one is available...an aftermarket vendor might offer one...?
Of course if utilized the change will naturally make all the gears longer accross the board....
Salsa1
posted April 21, 2010 11:04 AM
I hear a c14 uses a taller first gear ..
johnbull
posted April 22, 2010 03:57 AM
Interesting, thats the Kawasaki tourer 14 right?
68gts2
hobbies ( Beating you !!! )
posted April 22, 2010 04:25 AM
Yes.
johnbull
posted April 22, 2010 05:06 AM
Ok, Ive found all the ratios of all 3 bikes ZX12, ZX14 & Concours 14
ZX12
1st 2.429
2nd 1.824
3rd 1.440
4th 1.250
5th 1.130
6th 1.033
ZX14
1st 2.625
2nd 1.947
3rd 1.545
4th 1.333
5th 1.154
6th 1.036
Concours 14
1st 3.333
2nd 2.412
3rd 1.900
4th 1.545
5th 1.292
6th 1.074
As we can see, the ZX12 has a higher 1st gear and basicaly better overall ratios than the 14 for racing purposes.
Now the concours14 2nd gear is very close to that of the ZX12 1st gear (2.429-2.412)
If only it would fit! Any idea if this would be possible???
kawpower
Mr kawasaki 2 you!
posted April 22, 2010 05:09 AM
give robinson industries a call they will make what ever gearing u want.
johnbull
posted April 22, 2010 05:18 AM
Thanks, will give them a call.
salsa1
posted April 23, 2010 10:10 AM
Front sprocket changeout cost less and is far less labour intensive
Just suprised that avenue of posibility is not exausted befotre deciding to split cases for one single gear change...
Good luck!!
Salsa1
salsa1
posted April 23, 2010 10:16 AM        Edited By: salsa1 on 23 Apr 2010 18:28
Just suprised that avenue of posibility is not exausted before deciding to split cases for one single gear change...
Ok just in case ..this could help....my understanding is that the ZX-14 and ZX-12 front sprockets are interchangable...if the ZX-14 comes stock with a 17 tooth front sprocket...an 18 is easily available for $25.00 here in kneedraggers for the ZX-12R which may fit the ZX-14...
http://www.kneedraggers.com/details/AFAM_Front_Sprocket_Kawasaki_ZX12R--14-AFAM-146.html
Good luck!!
Salsa1
johnbull
posted April 23, 2010 10:37 AM
Good luck!!
Thanks for the suggestions, but going for a bigger front sprocket will change the ratio of all the gears (final drive ratio).
What we are looking for is a taller 1st gear for the engine in order to make 1st gear closer to 2nd.
Looks like Robinson Industries can do the job by bringing first gear down to 2.4 as opposed to the 2.6 stock ratio.
Cheers.
johnbull
posted May 20, 2011 05:08 AM
Taller 1st gear by robinson industries is brilliant.
GREYHOUNDMOSES
posted May 20, 2011 09:00 AM
This might be worth a read:
http://www.bikeland.org/board/viewthread.php?FID=27&TID=61037
0.24318909645081 seconds processing time
