BIKELAND > FORUMS > ZX-14.com > Thread: flys out problem NEW TOPIC NEW POLL POST REPLY
darrylez1
posted April 16, 2010 12:55 PM        Edited By: darrylez1 on 16 Apr 2010 20:57
flys out problem
07 14,I have a S-meg,pair removed ,stock air filter,no flys,running Brocks street map for baffle in, no flys ,stock air filter.The bike runs really strong but will not cruise in the city.The throttle feels like an off on switch under 3500.I have calibrated the PC throttle position sensor.Even my 24 year old son is complaining about it,he cant cruise and check out girls.Need help I dont want to put the flys back in
07 14 ,brock S-meg BST's,2012 14r BST's ceramic bearings,rear sets ,full Hindle Evo
SixSixoh6
posted April 16, 2010 01:11 PM
make sure you got the street map in and not the track. my buddy has a gixxie 1000 and with the track map in it bucks like crazy at 2500rpm..
LAB3
posted April 16, 2010 01:31 PM
Did you call Brock and ask???
granpa
posted April 16, 2010 01:53 PM
Check your vacuum hoses and throttle body boots for leaks.
darrylez1
posted April 16, 2010 02:18 PM        Edited By: darrylez1 on 16 Apr 2010 22:19
I have posted on Brocks forum,no reply yet.I will double check my hoses and boots.my kleen air is removed with a blocked hose tieing the spigots together, the airbox opening for the hose is plugged off and siliconed.Would it hurt to try a flys in map just to test?
LAB3
posted April 16, 2010 03:06 PM
Call Brock. ASk for Him on phone. His customer service is Great.
LAB3
posted April 16, 2010 07:04 PM
Quit playing with that SS Camaro and lets go to Ozark Mountains that Brocks
Smeg will rust if you don't get it hot lol :-)
Sorry thread jack.
Louis
darrylez1
posted April 16, 2010 07:29 PM
I will check hoses and boots tomorrow.If it was a carb bike I would think a low rpm rich problem.If hoses and boots not the problem I'll get her good and hot then a short run with air filter removed and see if anything changes.Is Brocks support open on saturday?
blackbullet76
posted April 16, 2010 10:49 PM
Check your ground wire on the PCIII, just a thought
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
darrylez1
posted April 20, 2010 02:49 PM
Problem solved,winter gas with stabilizer in it.Fresh gas and injector cleaner shes getting better and better
epd345
posted April 20, 2010 03:32 PM
Use Seafoam to stabilize your fuel, much better than standard stabilizer
0.28148221969604 seconds processing time
