BIKELAND > FORUMS > ZX-14.com > Thread: spark plugs NEW TOPIC NEW POLL POST REPLY
hardatit
posted April 04, 2010 09:25 AM
spark plugs
I went to the track on friday night made a pass and when I went to make my second pass my bike would turn over but not fire. It eventually started and ran 6.23at 117mph. But I recently took the flies out and got a map from muzzy and wondering if it could be too fat and trying to foul my plugs? 08 SE with muzzy m-10, bmc race filter,no flies, and pc3 and mps air shifter and kill tether. I know its not pc3 because I have already moved ground. So If you think it could be plugs what plugs should I put in when I change them? Thanks
SixSixoh6
posted April 04, 2010 12:07 PM
how many miles are on the bike? highly doubt its too fat of a map. if you took the flies out....it runs leaner
zx14fan
posted April 04, 2010 12:45 PM
The muzzy map is junk I had one.The online pc maps suck too you might want to have a dyno done to take some of the guess work out?
dcjens
Wet side of Washington
posted April 04, 2010 01:03 PM
Its hit and miss with Fuzzy maps. Looking at some maps, theyre all over the place fuel-wise. I eventually found a good one prolly from a member here. Emailing Fuzz didn't get me too far either. I switched brands
Black 06
LAB3
posted April 04, 2010 06:26 PM        Edited By: LAB3 on 5 Apr 2010 02:27
Depends on which Muzzy system you are running. I got a good working Muzzy map from Dave at Muzzy.free. Worked OK. But I have the M14. and the map for it sux on the old style Muzzy system for the 14, different head pipes etc. Several 14 owners went thru this, you have to make sure the map requires the advancer, flies in or out etc. Have to Very specific with them.
Dyno tune a custom map where you ride is best.
0.28245711326599 seconds processing time
