BIKELAND > FORUMS > ZX-14.com > Thread: Problems shifting with Sato Rear Sets NEW TOPIC NEW POLL POST REPLY
epd345
posted April 02, 2010 07:37 PM
Did a few hundered miles with the new rear sets installed last couple weeks and everything was fine. Went to go for a ride tonight and the bike would not shift into 3rd and up. So I pulled over and noticed there were some loose fitting and I tightened them all up. Still not shifiting into 3rd and up. 1st, neutral and 2nd are all fine. I was getting worried I was having a tranny problem but my bike has been babied. Anyone else out there have sato's on their 14 and ever run into similar issue
zixxer14
Damn that was Quick
posted April 02, 2010 09:16 PM        Edited By: zixxer14 on 3 Apr 2010 05:17
Have you tried switching back to stock to check that it isn't the tranny? Does it shift by hand sitting still while turning the rear wheel?
INTIMIDA2OR
RED rider!
posted April 02, 2010 11:05 PM
Is the shifter operating smoothly?
Is the shifter allowing the shift shaft to turn the full amount to engage the gears?
It sounds like there's something binding up .
'06 Passion Red ZX-14
*Lee*
epd345
posted April 03, 2010 02:48 AM
Put it all back to stock and its fine, must be a adjustment issue with the rearsets.
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:04 AM
Yup,yup! Git her done!
*Lee*
slates
posted April 03, 2010 06:09 AM
I have the sato's on my bike for several years now and no problems. I did however use the blue Loctite on all of the nuts on the shift bar to lock them into place once I got the angle on the shifter I liked. It sounds like you have something mounted incorrectly that's not permitting the full movement of the shift bar.
There are several picks of my bike and rearsets on this site...I can post one up of my shift side later today if you would like????
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:27 AM
*Lee*
Flame On
Fuel Air & Spark
posted April 03, 2010 07:20 AM
Sounds like the adjust may need to be tighter to shift rod or something never heard anything bad about sato. Was thinking of getting a set myself I like the passenger foot peg bracket set up that can be added.
77 RD 400
80 GS1000 GT
06 ZX14
slates
posted April 03, 2010 12:51 PM
here you go:
zixxer14
Damn that was Quick
posted April 03, 2010 01:18 PM
Nice, I like that gold on black thing! Those rearsets look to have more than enough adjustments to adapt to any whim.
posted April 03, 2010 01:22 PM
those rear sets allow so much "adjustability" that you can easily be off and the shifting be hosed in certain gears
nice rear sets! I set mine as low as possible for distance riding (comfort). knee-drag rides they go as high as possible.
epd345
Wow slates I had my shifter cog thingy mounted straight up and down and not canted back like yours. Thanks for pics! I will try mounting it like that !
INTIMIDA2OR
RED rider!
posted April 03, 2010 02:42 PM
I hate reading instructions too lol
*Lee*
Hellmutt
posted April 04, 2010 05:47 AM
here you go:
Wonder if you're able to flip the little pitman arm so you could shift inverted pattern? GP style!
epd345
posted April 04, 2010 07:49 AM
Sato does make the rear sets in reverse shift pattern. Not sure which part would be different from the normal rearsets.
INTIMIDA2OR
RED rider!
posted April 04, 2010 09:26 AM
I hate when rearsets aren't reversible !
*Lee*
SLVR_BLT
Chicken Strips!
posted April 04, 2010 10:57 AM
Ive always been a fan of direct action shifters, i hated bikes that had intricate linkages for the shifter, it took away from the direct feel and often made it where more effort was needed to shift. My Honda VFR800 had it direct as well as my 14, i really like it that way.
INTIMIDA2OR
RED rider!
posted April 04, 2010 01:32 PM
Yes direct shifters have the best feel but then you can't reverse it to GP or drag style shifting. And some models need linkage to actuate the shifter cause of the location of their shift shaft being way impossible for a direct shifter. The 14 don't have that problem
*Lee*
epd345
posted April 04, 2010 04:49 PM
Re-installed the Sato's using using Slates pic and all is well, thanks Again! INTIMIDA2OR thanks for the advice on reading the directions but there weren't any!!!!!
Flame On
Fuel Air & Spark
posted April 04, 2010 05:21 PM
Sato 's have a good rep on those good to hear I still am planing on buying a set myself.
77 RD 400
80 GS1000 GT
06 ZX14
CraigChrist
BAWLS
posted April 04, 2010 06:05 PM
i've never liked gp style shift. i guess it's the thousands upon thousands of runs i've made shifting with my foot under the lever.
60ft-------1.42
1/8th------5.97
mph-------119
slates
posted April 04, 2010 06:39 PM
I think you can get a gp style shift from Sato, but it's a different parts kit.
slates
posted April 04, 2010 06:41 PM
SLVR_BLT
Chicken Strips!
posted April 04, 2010 06:49 PM
can't you simply rotate the arm on the trans lever side downwards to make it shift reverse?
posted April 04, 2010 09:26 PM
vortex are reversable,
they all have to be adjusted in the middel of the throw, so the shift forks can push and pull every gear cog and engauge into place.
0.2471489906311 seconds processing time
