BIKELAND > FORUMS > ZX-14.com > Thread: Worst shifting bike I have ever owned NEW TOPIC NEW POLL POST REPLY
Acat
posted April 03, 2010 05:53 AM
Surely something is wrong, I dread shifting this thing. First 3 gears are the worst, clunking like the chain has a foot of slack. Very solid banging. WTF? I have the chain at the minimum adjustment. Just put in Motul oil hoping for a change. No diff. Would a Quick shifter help?
Bently
2012 14r In Blue and no Mods!
posted April 03, 2010 06:00 AM
IMo my 2 14s where the wost shifting bikes I have owned as well but the trannys are built solid and you will not have any issues from it. my main problem was going from N to 1st. I learned to do it with the bike not running. everyone that ever rode my 14 though I had a tranny problem. so just get used to it and it will not hurt anything.
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:10 AM
My Red shifts like butter. Can't even hear or feel the 1-2 shifts anymore.
My dads Blue clunks 1-2-3. I dunno
Must be the Red
'06 Passion Red ZX-14
*Lee*
zixxer14
Damn that was Quick
posted April 03, 2010 06:17 AM
Sometimes bad shifting is indicative of a bad or soon to be bad clutch. Plates not separating, indents on hubs, good stuff like that.
Bently
posted April 03, 2010 06:18 AM
Not the case with my 2. just shitty shifting. but they where not red ones so maybe that's it.
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:21 AM
Yes that's it!
Did you try replacing the clutches?
*Lee*
Acat
posted April 03, 2010 06:22 AM
So a repaint is in order?
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:23 AM
That's what I was thinking . Could be oil too. I wonder what he is using?
*Lee*
speedgene
Surely something is wrong and I've said over and over, this is a field fix the factory has no clue about. Mine shifts like no other. This hack needs to be upgraded/improved by the electronics team in Japan, not some round eye in corporate North America looking over my bike. I'd be embarrASSed/shamed/shunned/hair wee care pee I don't give a shit, really. They'll figure it out soon enough.
Say I have zero shifting problems with a loose chain just a touch more slack than max [book] slack. Try that. Yeah, I wish you could ride mine and you'd change your tune. I've never felt a smoother shifting bike than they've put out right here on the 14... I just tuned a trans is all.
E-tard
INTIMIDA2OR
RED rider!
posted April 03, 2010 06:25 AM
I hate to say it but your machine needs to be born red ,there are no short cuts
*Lee*
Bently
posted April 03, 2010 06:29 AM
Well one of my first post on this board was back in 2006 when I first got my 14 home and I asked if anyone else ever had as poorly shifting bike as mine cause I would have sworn something was wrong with it. then I had lots of feed back stateing that's the way most of them are in it would not hurt anything. I made over 1000 runs between the 2 14s with no issues. just gotta get use to everyone turning around and looking at you when you drop her in first gear and it sounds like the tranny just fell outLOL
posted April 03, 2010 06:32 AM
Both my 06 and 09 are the best shifting bikes i have ever owned ..
Acat
posted April 03, 2010 06:41 AM
Say what? Max slack will fix it?
SixSixoh6
posted April 03, 2010 07:08 AM
is your chain adjusted properly? whats your idle speed. my Neutral to First gear is pretty rough too. after that its all good. loose chain it can be a bit more severe. also low idle speed can cause this
posted April 03, 2010 07:22 AM
I have no problems as being stated here, but between my 636, 2 of my brothers r1 and a zx10 the 14 shifts the worst IMHO.
Bently
posted April 03, 2010 07:23 AM
I for one don't think it's a problem, just the nature of the bike.
dcjens
Wet side of Washington
posted April 03, 2010 07:26 AM
Mine shifts very smooth with or without the clutch
Black 06
Lucky14
posted April 03, 2010 07:31 AM        Edited By: Lucky14 on 3 Apr 2010 15:36
......... and both my 06 and my 08 were/are the best WHEN RIDDEN AS THEY WERE DESIGNED TO BE.
The exception: When I was following my wife around on her Ninja 250 and shifting at low rpms, the shifts were "clunky" - even horrible.
Neutral to first is a whole separate issue. Many Kaws do that, including my ZRX. It's just the clutch not releasing quickly. Pull in the clutch and hold it for 10 seconds, then go from neutral to first and see what happens - assuming that the idle speed is where it should be.
Acat
posted April 03, 2010 07:38 AM
I can live with the neutral to first Atomic Bang. Idle at 1100 RPM. It's just the rest...... Headed to the garage to increase the slack "A touch more than max [book]"
Lucky14
posted April 03, 2010 07:42 AM
One other thing. If it is "overfilled" with oil, even at the top mark, it may not shift as well.
I have no proof of this, except hearing this from others, and personally experiencing it once.
CraigChrist
BAWLS
posted April 03, 2010 08:24 AM
the 14 clunks a little bit but the shift is a very positive shift. I'm so used to it now that when i get on other bikes they feel like they're not in gear all the way when i shift lol. What you're saying sounds like a loose chain to me though.
60ft-------1.42
1/8th------5.97
mph-------119
speedgene
posted April 03, 2010 08:46 AM
http://www.youtube.com/watch?v=JLRgRYsePsg
E-tard
CraigChrist
BAWLS
posted April 03, 2010 08:57 AM
adding more slack won't make it shift better, but do what you want. RTFM
60ft-------1.42
1/8th------5.97
mph-------119
Acat
posted April 03, 2010 08:59 AM
WOW! That's loose!
INTIMIDA2OR
RED rider!
posted April 03, 2010 09:21 AM
+1
*Lee*
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.38295817375183 seconds processing time
