BIKELAND > FORUMS > ZX-14.com > Thread: A little dyno testing ....... NEW TOPIC NEW POLL POST REPLY
posted April 01, 2010 09:37 AM        Edited By: smokinZX14 on 1 Apr 2010 17:45
As most of you know i switched from a Brocks Smeg to his New CT single system ... The CT system same day same dyno picked up 2 HP at peak ( redline ) The good news is it picked up 3 HP from 3000 to 7000 rpms with a jump of 5 HP from 7400 to 9500 then it tappered down to 2 HP at peak ( redline ) .. I'm very happy with the gains and i really like the look and sound of the pipe .. That puts my bike at 172 HP 102 TQ at peak RPMs Vs 169 to 170 HP same day with the Smeg ..I'm using Brocks track map with my A/F running 12.9 to 12.7 6000 RPMs to redline ..
Brock kept bugging me to try his injector cleaner but i didn't think it would be worth it ... I don't care for things like "Valve job in a can" .To me that kind of stuff is like the "Sham wow " crap on TV ... After all i only have 2000 miles on my bike so why would it have dirty injectors ? But brock kept at me with the injector cleaner so i broke down and had him send me a can ... I did the test as brock told me to do , 16 oz of cleaner to two gallons pump gas and drove the bike about 10 to 15 miles ... First i put the bike on the dyno as is with 2 gallons of 87 pump gas ( no Injector cleaner ) and came up with 172 HP .. Then i added the injector cleaner and put 10 to 15 miles on the bike .. Then i drained all the fuel out of the bike and added fresh 87 pump gas .. I tossed the bike back on the dyno and pulled 175 HP ...WTF !!!! That's a 3 hp gain was across the the hole RPM range ( 3000 to 10,600 ) This was done same day same dyno and about 3 hours of each other ..No way injector cleaning would do that ..But the numbers are real and i made the test as fair as i could ... Also my A/F ratio line was much better after the injector cleaning .. It took out some of the dips and high spots making the A/F line very flat ..Next time Brocks asks me to do something i'm not going to ask why and just do it ..lol....
I should add what brock told me about the injectors .. He said if you run MR9 you will not need to do this injector cleaning .. He said the MR9 does a fine job of cleaning the injectors and carbon build up on the valves and pistons .. But if you are like me and only run pump gas in your motor you may see some gains ... The gains depend on how dirty your injectors are to start with .. Clearly mine were some what dirty... Brock has found that new bikes with low miles suffer from dirty injectors .. It has something to do with corrosion coating Kawi puts in the gas tank before shipping the motorcycle to the dealers ..I'm going to keep a can of this injector cleaner on hand and from time to time add some just to keep things in a good state of tune ....
SLVR_BLT
Chicken Strips!
posted April 01, 2010 10:07 AM
I been running Redline Fuel system cleaner on all my bikes from time to time, it works pretty well too. How much is that Brocks stuff?
madkawboy
posted April 01, 2010 10:14 AM
Smokin- Is the fuel injection cleaner made by Wynns and called Power Charge ?
- Zack
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
posted April 01, 2010 10:22 AM
- Zack
Yes Zack ..
SLVR_BLT
Chicken Strips!
posted April 01, 2010 10:32 AM
Oh how convenient, the Wynn company is just down the street from me in Azusa.
Lucky14
posted April 01, 2010 10:40 AM
Great info!
Thanks!
Brock
Sponsor
posted April 01, 2010 11:05 AM
Guys,
The 14's are not nearly as bad as the Suzuki's.... we have picked up over 10 HP on older Busa's!
Brock
Brock’s Performance
  Ignore this member    Click here to visit Brock's homepage.
Brock
Sponsor
posted April 01, 2010 11:07 AM
Also,
This product should not be confused with any type of typical fuel cleaner...it’s VERY ROWDY and not available over the counter.
Brock
Brock’s Performance
kawasakijockey
posted April 01, 2010 11:16 AM
Rowdy??... Is this the name of the next Brock's pipe?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
LeonidasZX14
posted April 01, 2010 11:23 AM
I run MR9 and after each use I put in Lucas FI cleaner just to lubricate the valves. MR9 is lethal if left in your bike. That Lucas is Rowdy to but it makes my stomach hurt.
09' ZX14
posted April 01, 2010 01:29 PM
how much for a can?
gilberjj
Friend of Fast
posted April 01, 2010 01:34 PM
$30 last time I checked...
posted April 01, 2010 01:36 PM
i have 3 cylinders running a hair leaner than 1.... i may be do for a cleaning. will this stuff react with POR-15?
Lucky14
posted April 01, 2010 03:29 PM
Sounds like a lot until you do the math.
$10 per horse.
LAB3
posted April 01, 2010 04:50 PM
Which Redline they make two?
ZX14Mike
posted April 01, 2010 06:39 PM
FYI..........if you poke holes in the air filter to let it breathe and richen the fuel map 5% across the range you should pick up 17 horses with the injector cleaner.
INTIMIDA2OR
RED rider!
posted April 01, 2010 10:58 PM
Very interesting!
'06 Passion Red ZX-14
*Lee*
posted April 02, 2010 06:26 PM
LAB3
posted April 02, 2010 07:07 PM
Plus $10.00 shipping... I went for it and ordered a bottle. Will see if I notice any difference,
may use it on 96 Vette, lot of miles on old cager. Used Redline for years, but never in ZX-14..
Louis
INTIMIDA2OR
RED rider!
posted April 02, 2010 07:09 PM
Louis
Report back !
*Lee*
CajunBoyz
posted April 08, 2010 08:42 AM
Good to hear another good story on this Wynns Power Charger
LAB3
posted April 08, 2010 05:59 PM
Brocks cleaner just arrived. Use a whole can in 2 gals??? Wow. that is $20.00 a gallon. It cost me $10.00 to ship to Texas. My 2007 has 7500 street miles always pump gas. 93 Usually Shell (have a credit card). Redline I use to use was not mixed this way. Bottle worked for 20 gallons of gas.But never in 14. Will try it tomorrow and run it all thru and re fill with Shell 96 and ride another 50 miles. Time to roll on with friends 14's and see if it helped my 14
Louis.
CajunBoyz
posted April 09, 2010 04:06 AM
LAB3, Keep us updated, Awaiting to hear your "seat of the pants" after you run this through there.
Bently
2012 14r In Blue and no Mods!
posted April 09, 2010 04:20 AM
think it's going to be real hard to feel if you get 2-3 hp on the street.
LAB3
posted April 09, 2010 04:32 AM
I agree, Was wanting to use in vette and 14, but................to expensive.
0.24481391906738 seconds processing time
