BIKELAND > FORUMS > ZX-14.com > Thread: PCIII Hub Firmware NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted March 18, 2010 04:40 PM
PCIII Hub Firmware
I just want to pass along some info just in case anyone else is having hub output enabling/disabling problems, such as consistency in it working or not. We were having these problems when using it as a window switch on a friend's 14. Acted almost like a bad wire connection. I called Dynojet and told them the problem and they emailed me a firmware update 2.3.3.0 that did the trick. I could not find that download on their website btw. Anyway, if anyone else is having these issues it should fix it. It seems to be more of an issue with the 2.3.1 PCIII and not so much the 3.2.1 or later..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
0.21870303153992 seconds processing time
