BIKELAND > FORUMS > ZX-14.com > Thread: Jesse got a little more power NEW TOPIC NEW POLL POST REPLY
SteddyTeddy
posted March 13, 2010 04:51 PM        Edited By: SteddyTeddy on 14 Mar 2010 00:59
Well since all the BS from the last thread Lee decided not to post up any more dyno charts. We were quite happy with the results today so I say Fuk it. 93 pump, 5 angle valve job, .020" shaved, CT exhaust. The bike was still pulling when it hit the limiter!
CraigChrist
BAWLS
posted March 13, 2010 04:55 PM
nice, now he's going to have to ride that beast.
60ft-------1.42
1/8th------5.97
mph-------119
SteddyTeddy
posted March 13, 2010 05:04 PM
posted March 13, 2010 05:41 PM
very nice, anything done to the head besides shaved and the valve job?
what CR is that at now?
kingtramp
posted March 13, 2010 06:57 PM
Nice bang from the mods
posted March 13, 2010 07:14 PM        Edited By: smokinZX14 on 14 Mar 2010 03:16
Super sport rules , can't touch the ports ... Around 13.5.1
posted March 13, 2010 07:27 PM
Tommy did a test spin on the bike and said it's pulling like mad ... He hit second gear and while in a wheely in second gear the chain come off .. The bolt for the rear axle adjuster bent into an S shape and the axle jumped forward tossing the chain off ..It didn't hurt any parts other that the Adjuster bolt ..Well Tommys Nuts did get some damage when the bike came slaming down....
posted March 13, 2010 07:30 PM
this happed at what wheel base? on the street?
CraigChrist
BAWLS
posted March 13, 2010 07:31 PM
yowza!
60ft-------1.42
1/8th------5.97
mph-------119
stock wheel base 17/40 gears ... yup on the street ..
posted March 13, 2010 07:34 PM
yowza!
yowzais is right bawls , you can believe how fast this thing Revs up even with the tall gears ..The motor has a hole new sound ..
wow.... talk about a fluke. hope nothing was badly damaged. so you are attributing this to a bad bolt? any pics of the failure? how far does the bolt stick out with that gearing?
posted March 13, 2010 07:41 PM
No damage that we can see other than the bolt ... The axle is all the way to the back of the swing arm slot , so the bolt is pretty far out ... It could have been a bad bolt because Jesse lost the factory bolts some time ago .. Jesse put the bike back to stock wheel base so i really don't know what grade of bolts he used ... I put a factory kawi adjuster bolt back in it and made sure the axle was extra tight ..
CraigChrist
BAWLS
posted March 13, 2010 08:14 PM
so what would those of us who are interested in going this route be looking at price wise.
60ft-------1.42
1/8th------5.97
mph-------119
kingtramp
posted March 13, 2010 08:23 PM
I had a similar problem, went to ace hardware bought case harden grade 8 bolts with less thread & more shank, no more problems in two years.
posted March 13, 2010 09:13 PM
Well i will have to ask Jesse what the head work cost but i'm thinking he said 200.00 ... The head gasket was 50.00 bucks .Adjustable cam gears about 35.00 bucks ..I will have to set down and count my hours for the Motor R&R , R&R the head , setting the valves and cam timming.. If you can do the labor yourself you would be out less than 300.00 bucks ....300.00 bucks for 13 HP is a good bang for your dollar ..
JDC
posted March 13, 2010 10:14 PM
very nice jump for the $
Bently
2012 14r In Blue and no Mods!
posted March 14, 2010 06:45 AM
Your right smoking that is some good power for 300.00. depending on what you would charge for your part it could still be cheap hp.
JDC
posted March 14, 2010 07:27 AM
You shaved the head clearance .020? ... most of the new power from the shaved head/higher compression?
CraigChrist
BAWLS
posted March 14, 2010 07:33 AM
i think it comes from the valve job
60ft-------1.42
1/8th------5.97
mph-------119
Bently
posted March 14, 2010 07:46 AM
I'm sure it's a combo thing. put it all together and it's good gains don't forget he degreed the cams as well.
Bently
posted March 14, 2010 07:54 AM
I can't wait untill jesse gets it to the track! if he can ride it it should put up some good numbers!
posted March 14, 2010 08:05 AM        Edited By: Shane661 on 14 Mar 2010 16:06
Those are fantastic results. The way it pulls to the limiter looks great. From all of the talk of how bad the 14 head is, it seems to flow pretty darn good with just a good valve job
CraigChrist
BAWLS
posted March 14, 2010 08:12 AM
so lee, when are you going to ride it so that we can see what it's capable of?
60ft-------1.42
1/8th------5.97
mph-------119
Bently
posted March 14, 2010 08:14 AM
I would guess if lee can get that much from his for that little money he might do his, I know I would.
0.28729486465454 seconds processing time
