BIKELAND > FORUMS > ZX-14.com > Thread: PC3 help... NEW TOPIC NEW POLL POST REPLY
blackmamba
posted March 07, 2010 03:57 PM
PC3 help...
Fly's are out, power commander program is on my laptop. Power commander green light is on when i turn the bike on.
My PC program will not communicate with my PC3 on my bike. I tried every port and even the auto option but it says PC not found.
Also when I got to load a map off the website it has a load all maps option. When I attempt to open this on my laptop it won't open it.
Also, does the bike need to be running to load maps and how do I reset throttle?
Help please....
thanks,
abe
www.packleader.org
Wheelie
Old Man
posted March 07, 2010 04:00 PM
update the software?
wee
SixSixoh6
posted March 07, 2010 04:02 PM        Edited By: SixSixoh6 on 8 Mar 2010 00:02
no the bike does not need to be running to load maps.
check your cable, try to swap with a different usb cord if possible.
Load all maps option? you shouldnt need to load a map off the website unless you dont have the CD...
yeah what wee said too
blackmamba
posted March 07, 2010 04:03 PM
How do i update the software?
www.packleader.org
makenna
posted March 07, 2010 04:04 PM
Did you download the Power Commander software to your laptop?
http://www.powercommander.com/downloads/general_downloads/pciiiusb_software/complete_install/PC3Usb%203.2.1%20Setup.zip
English is the only language that matters.
oilfieldtrash
Kawasaki enthusiast
posted March 07, 2010 04:10 PM
I had to start my bike for the power commander to communicate.
'07 white S.E. ZX-14 sold
SixSixoh6
posted March 07, 2010 04:12 PM
oh lordy, do you have the 9v battery hooked up to it while connected to the laptop???????
blackmamba
posted March 07, 2010 04:18 PM
it's working only when m bike is running! yes! now how do i set my throttle? i am in the program now and wondering what to do?
it's saying the difference between the open and closed is below the rec'd min.
how do i set this?
www.packleader.org
SixSixoh6
posted March 07, 2010 04:22 PM
you can only set the throttle with the key on, engine off> because you have to go from rest, to WOT in order to set it. it should be in one of the tabs along the upper portion of the PC screen. cant remember which off the top of my head. but go through them and youll see one that says "reset throttle position" click it. then you hit "set value" with the throttle closed" then WOT and hit save. something along those lines...sorry if im a bit off i do not have my pc in front of me
blackmamba
posted March 07, 2010 04:27 PM
that is gonna be tough...my pc3 only communicates when bike is running...i'm not trying to rev it to hell....is it a big deal to leave it alone?
www.packleader.org
SixSixoh6
posted March 07, 2010 04:28 PM
its a big deal!! youre setting the TPS recognized by the PC. your map and bike would run like doo doo without doing it. i do it EVERYTIME i change maps.
do you not have the 9v battery adapter?? that is used so you can make changes, "talk" to the PC and do everything else with the bike off
blackmamba
posted March 07, 2010 05:32 PM
no i do not have a 9v battery adapter...is this just a generic thing i can pick up from anywhere (like wal-mart)
thanks.
Abe
www.packleader.org
SixSixoh6
posted March 07, 2010 05:37 PM
no, you have to get it from dynojet. the person you bought it from should have sent it with... may be able to find one from a board member or fleabay
makenna
posted March 07, 2010 05:40 PM
Best advice I can give you:
http://www.powercommander.com/powercommander/TuningCenters/Default.aspx?State=Illinois
SixSixoh6
posted March 07, 2010 05:43 PM
https://cart.jetkit.com/p-832-pciii-usb-9v-power-programming-module.aspx
blackmamba
posted March 07, 2010 06:49 PM
So I cannot do this with bike running? I guess I will order tomorrow.
www.packleader.org
blackmamba
posted March 07, 2010 07:06 PM
Hell yeah...there is one in addison! I wil call tomorrow. I hope they stock that piece.
www.packleader.org
0.21463704109192 seconds processing time
