BIKELAND > FORUMS > ZX-14.com > Thread: ZX 14 runs too hot? NEW TOPIC NEW POLL POST REPLY
SLVR_BLT
Chicken Strips!
posted March 03, 2010 05:20 PM
ZX 14 runs too hot?
Is it normal for a ZX14 to have almost all bars up to the H mark on the temp gauge? I noticed riding slowly through LA traffic that the temp gauges rise up to perhaps 1 bar below the max? Its barely 70 degrees outside today, that has me kind of worried about the warmer summer months or trips to hotter places like Vegas on the ZX. Any insights would be appreciated.
epd345
posted March 03, 2010 05:29 PM
Its normal for them to run hot, its the nature of the beast. I live in the North East and its not uncommon for my bike to be running one under from the top when idling in traffic or riding slowly. Mine has never overheated or pissed anti-freeze.
Flame On
Fuel Air & Spark
posted March 03, 2010 05:30 PM
A ZX 10 front fender will make a big difference
77 RD 400
80 GS1000 GT
06 ZX14
Red1
posted March 03, 2010 05:36 PM
After the ZX-10 Front Fender a 2nd fan will help also!!
Red12/Blue14
biker
HU$TLER
posted March 03, 2010 05:41 PM
My bike would run 1 or 2 over half even in the Phoenix summers of HELL. But mine went to 1 bar below top in 50 degrees, my oil light flickered only a few times and then SEIZED !$!$!
Check your overflow bottle and make sure it didnt fill up on you, as mine did! My fuckin HEAD Gasket went and I HEAT SEIZED!!! CHECK YOUR WATER.
Run water wetter and straight water, no anti in the heat...she will run cooler.
SEIZED...REBUILDING HOT ROD TIME
SLVR_BLT
Chicken Strips!
posted March 03, 2010 05:47 PM
Oh damn, that sucks! What do you mean by make sure the overfill bottle didn't fill up on you? Isn't the coolant reservoir supposed to be at the full line?
Also something else i noticed was hot air hitting my legs, i mean its nice on a cold mornings to work but in the summer or hot days it would probably drive me crazy.
posted March 03, 2010 06:13 PM
It will run warmer till you get some miles on it .. 1500 to 2000 and it will start to run a bit cooler . Syn oil helps and water wetter can also help ...The heat on your legs , Well get used to it because they all do it ... What helps big time is tossing the factory exhaust .. .. also If you keep your legs off the grills by just an inch that helps .. Now go ride ...
SLVR_BLT
Chicken Strips!
posted March 03, 2010 06:22 PM
Its got 5700 miles on it, i bought it used. Only other thing i was thinking of is using that heat wrap on the exhaust header pipes.
sj1400
posted March 03, 2010 06:24 PM
SLVR,
Are you still using the stock exhaust ? They tend to run cooler when you ditch the factory exhaust.. 08's have 3 cats..
biker
HU$TLER
posted March 03, 2010 06:30 PM
When I looked at my bottle it was completely GREEN!! I had anti in her for the cold morning drives to work. My head gasket went and my radiator push water out into the overfill bottle. Make sure it is only on the full mark!! But I noticed it when I was half way to the office, by the time I turned around and a mile later she seized...Thank god I was only going 20mph in traffic!! It would of been BAD if that happened at full throttle at the Drag Strip....ouch!!!
JDC
posted March 03, 2010 06:36 PM        Edited By: JDC on 4 Mar 2010 02:44
Mine ran a bar cooler than you describe before the ceramic coating! go figure. Now it runs about as you describe.
They probably put the ceramic coating on backwards...
LOL
dcjens
Wet side of Washington
posted March 03, 2010 09:10 PM
I had a 10 fender and 2 fans. I went back to the stock fender recently and like it better. let it be hot like they built it. ignore the gauge and ride it.
Black 06
INTIMIDA2OR
RED rider!
posted March 03, 2010 09:48 PM
I remember my Red 14 ran hot liike that when I 1st got her and sid her 1st road trip to the Vegas bikefest in '06.
She actually got hot enough a few times to make the whole temp guage flash!
But that was only when she was new. Now at alomst 60k miles she runs really cool , and hardly ever goes above half for too long.
I am running water wetter and water only no antifreeze.
My dads Blue 14 runs 1 bar over half at all times no matter what temp unless it is very hot then the temp guage goes all the way to H, or if it's really cold it will have only one bar lit. But even if its really cold unless she's on the freeway she'll run one bar over half lol!
The Blue bike still has stock antifreeze in it... Gotta swap that out one of these days lol
'06 Passion Red ZX-14
*Lee*
zx14fan
posted March 04, 2010 12:35 AM
The second fan really works well for the street.You can get the kit with a 20 amp fuse that comes with it. not hard to install
Hellmutt
posted March 04, 2010 04:41 AM
I've seen these and considered getting one for mine -- looks like the best $45 to spend on keeping engine temp down -- definitely need to convert to the zx10 fender too.........the cooler the bike runs, the more power they make!!! I like the water wetter and have used it for track days, but that's rare anymore so I stick with antifreeze 24/7 just for ease of winter storage -- Personally, mine heats up something fierce puttin' around downtown so I tend to take the country roads around town.......sometimes I even make time - as long as the sheriff's not out and about
jarhead
posted March 04, 2010 05:09 AM
These are big bore bikes, they are going to run hot. It is good to be concerned but I think what you are seeing is pretty normal. To be honest, a second fan and engine ice or water wetter is not going to hurt but this motor is still going to run hot. If you are going to be idling in traffic keep you coolant topped off and change your oil and filter regularly with a good filter and synthetic oil. Then ride the wheels off it!
posted March 04, 2010 05:21 AM
What I am not understanding is why didn't kawi put a number temp like kn the zx6 and zx10's???? You knew the exact temp it was running, not how many "bars" I am running
dcjens
posted March 04, 2010 06:27 AM
I agree, I dont care for idiot lights and flashing gas pumps I'd like to cut in a digital gauge somewhere, maybe a 10 sender unit/gauge would work?
Black 06
posted March 04, 2010 12:05 PM
just ride it not a problem. aftermarket exhaust will help
INTIMIDA2OR
RED rider!
posted March 04, 2010 06:59 PM
I think it's more simple. C - H , keep it form lighting up the H and you're good.
*Lee*
busaisbetter
posted March 04, 2010 09:25 PM
my z1000 and zx14 reach all bar high in traffic. its normal.
Flame On
Fuel Air & Spark
posted March 04, 2010 09:31 PM
Yep keep her moving or shut off on long lights kick on the fan hit the start on green.
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted March 04, 2010 09:42 PM
Start worrying when the temp guage flashes shut it down ASAP!
*Lee*
INTIMIDA2OR
RED rider!
posted March 04, 2010 10:47 PM
There ya go!
*Lee*
dogszzr
posted March 05, 2010 11:49 AM
I would like to see number's also. I am switching to engine ice b4 the season starts.
0.23098087310791 seconds processing time
