BIKELAND > FORUMS > ZX-14.com > Thread: Shock Rubber NEW TOPIC NEW POLL POST REPLY
Wheelie
Old Man
posted February 22, 2010 08:37 AM
Shock Rubber
does anyone use the rubber shock spacer that stops the shock from bottoming out?
wee
Quarter Pounder
with Cheese
posted February 22, 2010 11:15 AM
don't know...but isn't that rubber there to keep the piston from bottoming out and damaging the shock?
Someone should know...
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
kawasakijockey
posted February 22, 2010 11:22 AM
Muzzys did have such a thing at one time called a shock travel limiter. Dont know if it is rubber or not. Give them a call.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SteddyTeddy
posted February 22, 2010 11:43 AM
Be very carfull trying to get that piece out. Last one I tried to pull apart I ended up getting covered in oil and coating the wall and ceiling in my garage. LOL
Wheelie
Old Man
posted February 22, 2010 11:50 AM
will a straight link help with the soft shock? Ive got to do something, I will get a swingarm in a week or so, but im hitting my tigertail now,
wee
posted February 22, 2010 11:52 AM
Raise the ride height in the rear if it is bottoming that hard.
SteddyTeddy
Should help some but your money is probably better spent on having a shock setup correctly.
Wheelie
Old Man
posted February 22, 2010 11:56 AM
so get mine revalved?
wee
posted February 22, 2010 11:57 AM        Edited By: Shane661 on 22 Feb 2010 19:58
Wee...what is the mystery here? You are a big guy. The stock shock has inadequate damping and preload for someone your size...you know this.
Cheap = revalve. Best = new shock. Your new arm isn't going to make the suspension behave.
Wheelie
Old Man
posted February 22, 2010 12:00 PM
whats NinjaBoy running?
wee
posted February 22, 2010 12:01 PM
wee
A Penske.
SteddyTeddy
$350 to $400 for a revalve and new spring, depending where you send it. Good aftermarket shocks start at around $600 and go way up from there.
Wheelie
Old Man
posted February 22, 2010 12:02 PM
wee
A Penske.
Pen$ke and a straightlink?
wee
posted February 22, 2010 12:04 PM        Edited By: Shane661 on 22 Feb 2010 20:05
wee
A Penske.
wee
Penske and a Straight Link.
The Straight Link is not designed to help with your suspension geometry...that is straight from Adams.
The Straight Link is for clearance.
Wheelie
Old Man
posted February 22, 2010 12:10 PM
I need to lower the rear more with the catalyst tail, did NB have a tigertail? I guess I need to ask him what he had with his 6" tail, or do you know?
wee
posted February 22, 2010 12:14 PM
I think he had a Tigertail?
Why are you set on lowering the rear more?? For looks??
Wheelie
Old Man
posted February 22, 2010 12:15 PM
lower is better, and it does look goofy sitting high
wee
06redzx14
posted February 22, 2010 12:20 PM
it isn't exactly a tiger tail. i think he made it himself
posted February 22, 2010 12:23 PM
wee
Goofy looking, like this?:
kawasakijockey
posted February 22, 2010 12:26 PM
Wheelie, you dont really have quite enough spring or valving. Landing wheelies will make one rub and make you think it is the power squat causing it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted February 22, 2010 12:29 PM
I did have a very long wheelie, but it is to soft for my weight, and when I go longer it will be even softer, getting a price on a Pen$ke shock right now
wee
kawasakijockey
posted February 22, 2010 12:37 PM
800+ for a Penske, 300 for a Litz revalve. You still have the busa spring?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted February 22, 2010 12:39 PM
sold the Booza spring
wee
kawasakijockey
posted February 22, 2010 12:40 PM
I think it would be the right spring for you if you go 8-10 over.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Wheelie
Old Man
posted February 22, 2010 12:50 PM
the Pen$ke? im going 12 over
wee
0.22554993629456 seconds processing time
