zx14durham
4n21
posted February 21, 2010 04:17 PM
Motor going, shiny particles in oil.
Installed cycle logics lockup yesterday I brought off member here, After I completed install & began pouring oil out of pan into container under bright light, I saw some tiny shiny particles in oil. Bike has ran fine up too this point, I have a spare so Im not worried. I was wondering if anyone saw tiny particles in their oil & bike still run for awhile afterwards. After seeing this I listened too the engine with a stethoscope & could here a light knock, I compared the sound to my buddy's bike & I did not hear the knock. I guess I will be changing motors here shortly. What else is a good indicator of bearing failure, I heard of cutting open the oil filter.
posted February 21, 2010 04:24 PM
gold specs?(copper from the center of the shells)
pull the plugs to see if your pistons have made contact with them
posted February 21, 2010 04:40 PM
what year ? what mileage ? what oil? what type of riding ?
zx14durham
4n21
posted February 21, 2010 04:47 PM
06, 10,000 miles, Drag a little, 60 shot of nitrous, Amsoil synthetic. Sprayed mabe 20 times, Can't count the number of hard launches & full throttle runs.
kawasakijockey
posted February 21, 2010 05:02 PM
quote: Installed cycle logics lockup yesterday I brought off member here, After I completed install & began pouring oil out of pan into container under bright light, I saw some tiny shiny particles in oil. Bike has ran fine up too this point, I have a spare so Im not worried. I was wondering if anyone saw tiny particles in their oil & bike still run for awhile afterwards. After seeing this I listened too the engine with a stethoscope & could here a light knock, I compared the sound to my buddy's bike & I did not hear the knock. I guess I will be changing motors here shortly. What else is a good indicator of bearing failure, I heard of cutting open the oil filter.
have you strained the oil through a cloth to make absolutely sure it is metal?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SixSixoh6
posted February 21, 2010 05:36 PM
i highly doubt the motor is going, i mean as the motor wears its going to wear some of the metal naturally. pssh as long as that bad boy is runnin strong i wouldnt worry about it.
when i worked on cars it wasnt uncommon to see "shiny" oil during a lube change
Quarter Pounder
with Cheese
posted February 21, 2010 05:53 PM
can't be the motor...he's running the almighty amsoil in it.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
zx14durham
4n21
posted February 21, 2010 07:06 PM
Don't plan on removing it until it gets a significant knock, Loss of oil pressure, or starts to run bad. Interested in seeing the inside of the motor too see the affects of the Nos on the pistons & too see if there was any contact between the pistons & valve due to valve float with stock springs on the 60 shot. My other motor has the valve springs & retainers plus head work. I wanted too see how the motor would hold up. I will rebuild this motor after I put the the other one on the bike, I just don't beleive in buying a lot of expensive parts unless it's needed, Rods, Pistons, & So on. I watched too many people go threw their motors with all good stuff & have more problems than the guy beside them that remained stock with everything else remaining the same. Plus I ride a lot on the street, So my bikes can never be dedicated to race only. The funny thing is, My bike ran it fastest 1/8 mile time on motor the last time at the track and hasn't been ridden 5 miles since.
posted February 21, 2010 07:13 PM
just pull the oil pan and you will know for sure if its fine or not
zx14durham
4n21
posted February 21, 2010 07:53 PM
Should there be a lot of particles in the bottom of the pan.
NOX
PMRA / TMRC Super Street 4022
posted February 21, 2010 07:58 PM
Cut the filter, with a filter cutter........
That will show you........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
INTIMIDA2OR
RED rider!
posted February 21, 2010 11:29 PM
+1
If a bearing is going it will all be in there especially if its enough to make a knock
'06 Passion Red ZX-14
*Lee*
INTIMIDA2OR
RED rider!
posted February 21, 2010 11:30 PM
quote: i highly doubt the motor is going, i mean as the motor wears its going to wear some of the metal naturally. pssh as long as that bad boy is runnin strong i wouldnt worry about it.
I agree
*Lee*
