BIKELAND > FORUMS > ZX-14.com > Thread: Autotune problem NEW TOPIC NEW POLL POST REPLY
johnbull
posted February 09, 2010 09:58 AM
Autotune problem
I have a problem with the autotune of my PCV. It doesnt seem to be taking any readings and once I conected up the lap top (yes the autotune is selected on the software), the AFR figure on the right of the screen is just remaining 0.00, plus all the trims remain 0 aswell which clearly shows that the autotune is not functioning.
The Autotune unit just keeps flashing red continuously with out change. I also tried pressing the button on the front of the autotune unit for 3 seconds as the manuall states in order to check the lampda sensor but nothing happens, the red flash just remains the same.
Any suggestions anyone other than "buy a new one"????
John Bul Racing. Malta.
posted February 09, 2010 10:02 AM
Call dynojet ....
wrongway
posted February 09, 2010 02:49 PM
there is a terminator for the can bus that you need to plug into the auto tune. It wont work without it plugged in.
Roy
mathews
posted February 09, 2010 05:57 PM
Roy
That was the mistake I made.He is right
johnbull
posted February 10, 2010 05:05 AM
Thanks for the info. Going to try it in a couple of hours & hope that this solves it.
Will let you know.
Cheers.
johnbull
posted February 10, 2010 05:29 AM
Is the PCV meant to have a termination plug to in the open CAN port??
wrongway
posted February 10, 2010 05:44 AM
yep
roy
johnbull
posted February 10, 2010 05:57 AM
Cheers Roy,
So you are saying there should be 2 termination plugs, 1 on the autotune and 1 on the PCV, Correct??
mathews
posted February 10, 2010 11:56 AM
Just on the PCV I believe
chrisdhall
posted February 10, 2010 12:40 PM
I have both termination plugs in place
wrongway
posted February 10, 2010 04:28 PM
I just cked mine again. terminators in both ... but I have run it with just the terminator on the PCV.
it did not see the autotune without the PCV terminator installed.
Roy
johnbull
posted February 11, 2010 11:26 AM
Still no luck. This evening I'm going to check the wideband sensor on a friends unit to see whether it is the sensor thats gone. I've heard that these sensors can go pretty easily when being used in conjuction with racing fuel!!
wrongway
posted February 11, 2010 11:50 AM
I just checked my pcv/autotune out
with the laptop plugged in and bike off , you will see 0.00 on the afr
once the motor is started and battery power is supplied, you will see 9.99 until the sensor warms up , ( 30 seconds ) , then get a corerect reading.
It appears that the pcv is not gettign battery voltage? where is the pcv getting power from ?
Roy
johnbull
posted February 12, 2010 09:13 AM
Just tried a new wideband sensor and its still doing exactly the same thing, staying on 9.99.
The PCV only has a ground wire otherwise it gets its supply from the wireing harness connectors correct?
posted February 12, 2010 09:24 AM
Call Dynojet !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
wrongway
posted February 12, 2010 09:49 AM
but the autotune has a 12v connection to the battery , and that should be a switched connection , or the heater will always be on. are you sure you have 12v going to the autotune ?
Roy
johnbull
posted February 12, 2010 11:41 AM
Yep, thats connected all as it was before, the ground to ground and the positive comes on with the ignition.
The PCV has 2 lights on it. 1 is the green power light which is working, the other is the red status light.........what is that LED meant to do.....mine is never coming on!
brunocbrxx
posted July 13, 2010 08:11 AM
Did you press the "get table" button on the PCV software ???
1badzx12r
posted July 13, 2010 08:56 AM
great product works perfectly order another 1
0.21443295478821 seconds processing time
