BIKELAND > FORUMS > ZX-14.com > Thread: Spencer Cycle "sure shift" kit NEW TOPIC NEW POLL POST REPLY
SixSixoh6
posted January 28, 2010 02:07 PM
has anyone used this kit or know anyone that has?? its significantly priced lower than an MPS kit from mpsracng or anywhere else.
is there a reason its so much cheaper?
posted January 28, 2010 05:55 PM
from what I have seen a lot of brand name stuff is marked up a lot compared to if you pieced it together yourself(IF you know how)
what kill box does it use?
SixSixoh6
posted January 28, 2010 07:01 PM
apparently it uses the MPS kill box. and sounds just like an MPS kit. says it includes everything for install
http://www.spencercycle.com/product_p/sp-2600c.htm
gilberjj
Friend of Fast
posted January 28, 2010 07:14 PM
you can use the dynojet quickshifter software if you know how to do it........ problem is....... I don't know how to do it.
dogg24
posted January 28, 2010 07:30 PM
2012 ZX14R SE, Streetmeg, PCV
SixSixoh6
posted January 28, 2010 08:36 PM
thx for the assist dogg. gilber- i have used the quickshifter setup on my last bike. i will admit it worked flawless. its just the whole getting my feet up on the pegs to shift! and the setup pretty much costs the exact same as an airshifter...but is very very compact.
SixSixoh6
posted January 28, 2010 08:41 PM
well shoot...its $276 on the dynojet site...that may be worth a try. and all it is is one linear sensor....what do you guys think??
Douglas Home
posted January 28, 2010 09:53 PM
My quickshifter , once set up , is great.
If you purchase one , let me know and I'll give you exact measurements to drill the gear lever.
I always wondered if you just purchased a momentary switch mounted for your left thumb and connected to the the pins on the PC that the quickshifter plugs into , then borrowed the software disk that comes with the quickshifter. Then just preload the gear shifter and hit the button when the shiftlight flashes.
Anyone done this? would be cheap as a $2 hooker!!!
Doug Mackay Australia
SixSixoh6
posted January 28, 2010 11:24 PM
yeah people have done this too. i think some have strayed away from it though because its another thing to think about ya know? youd then have to worry about moving you foot AND pushing a button.
BIKELAND > FORUMS > ZX-14.com > Thread: Spencer Cycle \"sure shift\" kit NEW TOPIC NEW POLL POST REPLY
0.34256196022034 seconds processing time
