BIKELAND > FORUMS > ZX-14.com > Thread: PCIII Hub Problem NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted January 23, 2010 09:45 PM
PCIII Hub Problem
PCIII hub outputs were working on a bike yesterday but will not trigger today. There was no shorting of components or anything like that. No matter what I configure the outputs for, they wont trigger. It could be a bad hub. Any ideas?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Compton
posted January 23, 2010 10:40 PM
does the LED light up on the hub? or does the power commander light up?
when mine did this, it was a battery issue.
b.w.
kawasakijockey
posted January 24, 2010 09:10 AM
Thanks for the help, you were right.
The lights were on with the 9v plugged in but evidently it wasnt strong enough. So I resent the configuration with the bike running without the 9v bat and it is working now. Those 9v batteries sure dont last long.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
06redzx14
posted January 24, 2010 04:09 PM
after my experience with the firmware updates using a 9V. I always start with a fresh one now. I had to have ithe PC reset
Bad in Black
posted January 24, 2010 06:05 PM
I use a 9 volt ac adapter, I plug it in the wall and have unlimited 9 volt life.....really makes setting things up a breeze. if you look around you can find adapters with a 9 volt style cap that plugs into the power commander adapter....I think I payed 10 bucks for mine.
kawasakijockey
posted January 24, 2010 06:21 PM
Good idea. I will look for one tomorrow.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.2796938419342 seconds processing time
