BIKELAND > FORUMS > ZX-14.com > Thread: Anyone running new clutch setups? NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted January 20, 2010 07:43 AM        Edited By: kawasakijockey on 20 Jan 2010 15:43
I am still considering a multistage but havent quite made up my mind. I chased the setup on my single for a good bit of time but the multi seems to be easier to tune to me. If money was not an object the Hays would be on its way. So, what are y'all doing this season?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted January 20, 2010 07:46 AM
Probably good old hand clutch.
Compton
posted January 20, 2010 07:50 AM
hand clutch / stock clutch.
just trying out different springs/spacers.
b.w.
Bawls
re-learning to ride
posted January 20, 2010 07:57 AM
try getting in touch with NOX. He's the man when it come to multi stages.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted January 20, 2010 07:59 AM        Edited By: Shane661 on 20 Jan 2010 15:59
I would seriously consider a multi or Hays, but I don't want to spend half of the season learning to tune it.
Seems like a lot of trial and error??
1badzx12r
posted January 20, 2010 08:07 AM        Edited By: 1badzx12r on 20 Jan 2010 16:07
with a 1.30 something 60ft what more do you want .. me just hand clutch
06redzx14
posted January 20, 2010 08:08 AM
has anyone tried the adam's springs and spacers?
kawasakijockey
posted January 20, 2010 08:23 AM
The Hays has been quite easy to tune for mostly everyone that buys them it seems. Multis seem to eat people's lunch....and clutch plates.lol
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted January 20, 2010 08:30 AM
Not much more on the short times really, just better big end. Getting a single tuned right usually means it gives up a little on the big end. I am off a few hundredths from last year. It is only a thought right now..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Compton
posted January 20, 2010 09:15 AM        Edited By: Compton on 20 Jan 2010 17:15
I have a set at my house, they are real heavy. I believe it was around 82lbs per spring/spacer. spacer alone added close to 20lbs. I wouldn't run all 5 unless you are making 300+ hp to the rear tire.
b.w.
1badzx12r
posted January 20, 2010 09:23 AM
surely you ain't talking about with a lock-up also are you
kawasakijockey
posted January 20, 2010 09:25 AM
What springs are you running with that turbo?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
1badzx12r
posted January 20, 2010 09:30 AM
stock
Compton
posted January 20, 2010 10:30 AM
nope, stock hand clutch and the adams real street clutch setup isnt really needed unless you are making 300+ to the tire, imo..
b.w.
Bawls
re-learning to ride
posted January 20, 2010 01:46 PM
I'm running brocks heavy springs and like them. my short times aren't all that great, but my mph is up since putting them in.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted January 20, 2010 01:49 PM        Edited By: Shane661 on 20 Jan 2010 21:50
I'm not sure of what clutch I'm going to run, but I'm out to kick some ass! (in an ET sense, that is)
Bawls
re-learning to ride
posted January 20, 2010 01:53 PM
sooooo you do know that i'm deploying again right? It's not going to be very easy for me to ride your bike when i'm in south east asia.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
kawasakijockey
posted January 20, 2010 01:56 PM
Spend that play money on the Hays...
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 20, 2010 02:07 PM        Edited By: Shane661 on 20 Jan 2010 22:07
Those slider clutch bikes sure seem quick:
posted January 20, 2010 02:15 PM
running my "voodoo" mtc lock up. its not sure if its a single stage or multi stage. i have some arms held back with springs to "kick in" later than the rest. it let me back off the weight a bit on the first arms to my NA setup, and the other arms come in later to hold the extra power if i spray. just running it as a normal single it would wheelie bad if i had a lot of weight on it (for spray). the chassis also wasnt right, so that played a big part too. i was getting close at the end of the season. IMO a multi is the way to go if you have a big power adder or a short bike. singles are fine for na
kawasakijockey
posted January 20, 2010 02:48 PM        Edited By: kawasakijockey on 20 Jan 2010 22:48
I did try this exact same thing on mine and it felt like a multi. Then I exploded a spring and havent tried it again. Since Cycle Logic has the new arms with dual weight holes, I might fiddle again with it this summer..if I dont buy a multi first.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 20, 2010 04:31 PM
Tim Hays wants over $100 for his conversion kit, and will not sell just the springs seperate. I spent $6 (yes six) at RCC and made something similar to the Hayes setup. IMO better. Tim wasnt helpful at all. Richard had EXCELLENT customer service. for that reason I will never have a Hays clutch. the next one i get will be a multi, more than likely a gen 2 by MTC
kawasakijockey
posted January 20, 2010 05:41 PM
What is RCC? I may check them out.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted January 20, 2010 05:45 PM
http://www.rccturbos.com/
Compton
posted January 20, 2010 06:09 PM
slider is a lot of fun, just sucks having to get pushed back and forth
b.w.
0.22697687149048 seconds processing time
