BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 smoke tail light. NEW TOPIC NEW POLL POST REPLY
sweetfa65
posted January 17, 2010 04:07 PM
Hey Guys.
I'm looking for a smoke tail light for my bike. I've already got the smoke indicators.
Every tail light I've seen has the turn signals integrated. I don't want that, I just want a smoke tail light with a full set of red led's.
Can anyone point me in the right direction
'2013' SE Spark Black & Golden Blazed Green ZX14R. Bog stock after trading my 07 ZX14.
68gts2
hobbies ( Beating you !!! )
posted January 17, 2010 05:09 PM
Try Clear Alternatives they list a oem smoke replacement taillight. Hotbodies also list one,but I would be very afraid of their stuff.
LAB3
posted January 17, 2010 06:52 PM
I have tried several, the $40.00 smoked tail lights on Ebay leak and need to be resealed before you install. Buy the spray and clear and smoke the stock tail light to match. Use
Very light coats. OEM tail lights are made better......................... You don't have to wire up the turn signals on the intergrated .
I have seen the smoked tail lights go from $40.00 to $95.00 each on Ebay. If you buy a aftermarket add some sealer around the lens and do not use Car Wash near tail light. And
some of them use a different bulb and different socket you have to cut and splice.
sweetfa65
posted January 17, 2010 07:03 PM
Very light coats.
I've never tried the spray version, but I might have a go at it. I've heard of a translucent spray called "Dark nights" over here in Aus.
What spray works the best? And do you just clear over it afterwards?
Cheers.
LAB3
posted January 17, 2010 07:11 PM
I purchased spray called Nite-Shades.........VHT and a can of Dupli-Color
Acrylic Clear Enamel. Both were in a kit. Will have to look and see where I purchased these on line.
TooHype
Go Hard or Go Home !!
posted January 17, 2010 07:22 PM
And
The smoked tail light that I purchased from Clear Alternatives was intergrated but only if you wired the turn signals, other wise it was just the one factory plug and it would function like the factory light.
epd345
posted January 17, 2010 08:14 PM
Got a pic of that smoked tailight TooHype?
zx-twitch
the dude abides
posted January 17, 2010 10:46 PM
if tohype doesn't have a pic I'll snap one for ya in the morning. I am also running the clear alternatives smoked tail light
TooHype
posted January 18, 2010 05:10 AM        Edited By: TooHype on 18 Jan 2010 13:10
[URL=http://img96.imageshack.us/i/lite2.jpg/][/URL]
[URL=http://img691.imageshack.us/i/lited.jpg/][/URL]
sweetfa65
posted January 18, 2010 03:47 PM
Thanks for the help guys.
I'll try and round myself up one of the clear alternatives ones.
Cheers.
epd345
posted January 18, 2010 04:12 PM
Thanks for the pic
sweetfa65
posted January 18, 2010 08:17 PM
Thanks for the pic
+1. Thanks for the pics.
SixSixoh6
posted January 18, 2010 08:21 PM
+1 on the nite shades
SnuffyZX
posted February 14, 2012 05:39 PM
Hey Fellas
Im installing a clear alternatives tailight on my 14R and want to make sure I am hooking up the signal part correctly. Its says to splice the turn signal wire with the positive wire on the signal lamp on the bike and my choices are black and yellow which I think is the negative and green which I think is the positive can anyone confirm this to be correct?
Snuffy
2012 S.E. Golden Blazed Green 14R
Brocks CT Dual Exhaust
Brocks Ohlins Damper
Ohlins Rear Shock
MRA Touring Screen
DDM HID's
COX Radiator Guard
Power Bronze Tire Hugger
Clear Alternatives Intergrated Tailight
2007 Candy Plasma Blue (Retired)
SnuffyZX
posted February 14, 2012 07:23 PM
Figured it out Thanks Snuffy
Ohlins Rear Shock
MRA Touring Screen
DDM HID's
COX Radiator Guard
0.24682593345642 seconds processing time
