BIKELAND > FORUMS > ZX-14.com > Thread: need jis screwdriver for flies NEW TOPIC NEW POLL POST REPLY
oilfieldtrash
Kawasaki enthusiast
posted January 13, 2010 07:05 PM
I finally removed the fly that had a stripped out screw with some 90 degree needle nose pliers. Well Im not taking anymore chances. I was told to get a jis screwdriver and thats what I'm doing. I googled jis screwdriver and they are all small ones. I want a long one with a hardened tip. Where did you get yours. Thanks.
'07 white S.E. ZX-14 sold
zixxer14
Damn that was Quick
posted January 13, 2010 07:15 PM
I steal mine from the japanese optical instruments I work on, they're nice enough to include them in the box. I know it doesn't help but....
LAB3
posted January 13, 2010 07:49 PM        Edited By: LAB3 on 14 Jan 2010 04:11
[url]http://www.rjrcooltools.com/vessel.cfm[url]
I found a set of 4 on Ebay last year. I Googled JIS screw driver and found several.
TooHype
Go Hard or Go Home !!
posted January 13, 2010 07:59 PM
SixSixoh6
posted January 13, 2010 08:21 PM
you could also try to use some valve grinding compound on the end of the screwdriver to help grip the screw to get it out
Douglas Home
posted January 13, 2010 09:05 PM
Heat the screw driver tip up and hold it on snug for several seconds to melt the locktite.
I just used a new good quality phillips (cant remember the size) , the heat and had no trouble!
Doug Mackay Australia
BobC
posted January 14, 2010 04:45 AM        Edited By: BobC on 14 Jan 2010 13:01
Try these:
http://www.rjrcooltools.com/vessel.cfm (assist)
and http://www.centralhobbies.com/Tools/jis.html
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
oilfieldtrash
Kawasaki enthusiast
posted January 14, 2010 05:57 AM
Thanks for the help. I found a set of four on eBay. They have the skinny handles but if I need to I will wrap some electrical tape around it for more gripping area.
Quarter Pounder
with Cheese
posted January 14, 2010 02:26 PM
I just removed mine today....really all ya need is a new #2 phillips and a soldering iron I put the tip of the hot iron on the screw heads for about 20 seconds (you can hear it sizzle), then moderate pressure on the screwdriver and tighten first a bit and then back out the screw. You can feel it if it's trying to strip or back out. Just take your time.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
AcadianaZX
Advertiser
posted January 15, 2010 06:27 AM
+1
oilfieldtrash
Kawasaki enthusiast
posted January 15, 2010 06:45 AM
Well last night I was fed up with the screws. I heated a screwdriver up with a propane torch till it was glowing red. I set it on the screw for about 45 sec then I used the long 90 degree needle nose pliers I picked up from o'reilly auto parts to break the screw loose. Then I backed it out with the screw driver. I didn't bother unhooking the gas tank. I propped it up with a 2X4 and that worked great. I am so glad that's done! I have the flies out and my power commander 3 hooked up. I plan on installing my Brocks alienhead exhaust tomorrow and installing the custom map I got from Brocks!!!! Hell Yeah!!!!!
Quarter Pounder
with Cheese
posted January 15, 2010 09:25 AM
allright!!!! I know it feels good to get it done.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
gilberjj
Friend of Fast
posted January 15, 2010 09:58 AM
I did the same thing........ except I used a lighter...... haha. It all works!
Superman T
posted January 15, 2010 01:07 PM
oilfieldtrash- you will be happy with the power increase, be prepared to smiled from ear to ear!
epd345
posted January 17, 2010 04:59 PM
Ya I gotta do the flies on mine next! Will that void my "good times" extended protection plan ?
LAB3
posted January 17, 2010 05:30 PM
Damn good question. My 2007 is still in warranty with the "good times".
epd345
posted January 17, 2010 08:03 PM
ANYONE? ANYONE? BUELLER?
LAB3
posted January 18, 2010 05:42 AM
New topic to post. Or call a out of town kawasaki Dealer and ask ummm most of them
would not know either. :-) If I have a bad engine failure, I will install ALL the stock parts back.
epd345
posted January 18, 2010 03:12 PM
Me too
chrisdhall
posted January 19, 2010 08:38 AM
I got my JIS screwdrivers from here: http://www.ikaswebshop.com/jisphilips.html
Different shaft lengths available - to remove the flies you need at least a 6" shaft (don't we all she cried!)
LAB3
posted January 19, 2010 09:54 AM
Good find.
LOCK 2121
posted January 19, 2010 10:41 AM
The JIS type screwdriver's would be best seeing how they fit right , but through the year's have found that the Klien brand driver's have the best tip for small screw's, use them all the time , computer's to motorcycle's car's ect. they are made for electrical work,it's all I will use, they dont wear out !
LAB3
posted January 19, 2010 11:18 AM
Snap-On and Mac have some good quality drivers, but a bit more $$ If they are as good
as some old Kllein wire cutters/plyer that my Dad (90) had in his tool box, Good Tools.
I have used Phillips on JIS for 35 years on old jap bikes and cagers, just knew when to
not over tighten, it's a feel that you have to break a few to understand :-)
After seeing the prints and read about the two different drives I wish all my drives were JIS but costs just too much to try to find Snap-On Black handle drives to match the set I have. Not even sure if if they make JIS.
Louis
LOCK 2121
posted January 19, 2010 04:03 PM
Snap on has driver's with hardened tip's , both Snapon and Kline tool's, top of the line!!
the price reflect's it ! when you work tool's daily, quilty means everything , once a phillps, get's slightly worn, better throw it out , just ruin's screw's.
noticed somone here started a thread on JIS sizes, I will follow their advise and have a set before I pull the bike apart, the screw head's have smaller slot's , nice to know you can get those fly screw's out with vise grips, if ya strip one , can't wait to get in their !
0.32540893554688 seconds processing time
