BIKELAND > FORUMS > ZX-14.com > Thread: Fuel pump going South? NEW TOPIC NEW POLL POST REPLY
davej
posted December 29, 2009 05:38 PM        Edited By: davej on 30 Dec 2009 01:38
Almost 36k miles now have a new problem. Throttle response hesitates then kicks in. It was slight then more severe. A ZX-14 in Utah is like snow shoes in Florida. The filter is in the fuel pump and is the first suspect. Advise? Can get to the machine shop next week and hook up all the test gauges. Experience counts and saves time.
Triumph guy
1badzx12r
posted December 29, 2009 06:04 PM        Edited By: 1badzx12r on 30 Dec 2009 02:38
what you need to know .. you can pull the filter out of the fuel pump .. it also can be you regulator.. maybe a boost leak or more boost .. injectors ...power commander ..
INTIMIDA2OR
RED rider!
posted December 30, 2009 06:53 PM
My experience with zx-14 fuel pumps going south has been a complete failure. At 40,000 and change one came into my shop with absolutely No action from the fuel pump . The bike ran perfect untill it was shut off. It wouldn't re-start and a new fuel pump fixed it.
The owner said no warning signs at all ,just wouldn't start all of a sudden.
Could be your bike needs a throttle body sync?
'06 Passion Red ZX-14
*Lee*
davej
posted December 30, 2009 07:12 PM
Throttle body sync is perfect, road many miles is salty wet conditions. When I can ride it to the shop and clean the connections and do a further inspect. Don't have a trailer so must ride in good weather. At this many miles must look at everything. The ZX-14 is a true street bike with a lot of abuse. Nothing compared to what you guys do though. It is still a good daily ride but tweeky with the turbo and do not wish to damage the motor.
Triumph guy
INTIMIDA2OR
RED rider!
posted December 30, 2009 07:22 PM
Sounds electrical... If you have access to a dyno the problem can be narrowed down by seeing what the air fuel looks like at the rpm the problem exists at , and the dyno operator should be able to see if the spark cuts out at a certain rpm.
*Lee*
davej
posted December 30, 2009 08:07 PM
After I do the basic maintenance, Salt Lake Motorsports will take a look if can't find the problem. Snow, snow for now. Will not take this to the local Kaw dealer, the Ducati mechanics Know their stuff and have a reliable dyno.
Triumph guy
0.27001595497131 seconds processing time
