BIKELAND > FORUMS > ZX-14.com > Thread: aftermarket cams NEW TOPIC NEW POLL POST REPLY
Compton
posted December 23, 2009 05:56 AM
aftermarket cams
Who has tried what, and what works well?
megacycle? web? muzzy?
b.w.
Darkforce
06 Tomahawk Cruise Missile
posted January 02, 2010 09:38 PM
man, dont think ur gonna get an answer 2 this question. i would like 2 know myself but it seems as though this is like top secret info! No 1 will hardly speak on cams and/or head jobs. lol
Compton
posted January 02, 2010 09:39 PM
Sucks, i wouldnt mind trying something out. But 1200-1500 is steep!
b.w.
Bawls
re-learning to ride
posted January 02, 2010 10:02 PM
have you asked around over on psychobike?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
davisag
posted January 03, 2010 03:17 AM
hi
i am running carpenter race cams , along with the valve spring kit tit retainers , and modded zx12 cam tensioner. i also have j&e 13.5-1 pistons, balanced crank and rods , and a ported head .
power comander, and ignition module fitted , crankcase breather mod done , worth 2-3 hp , and full ti force ex system , and makes 210 hp din on dyno
posted January 03, 2010 05:31 AM
You can't run very much of a cam without changing pistons, afaik.
posted January 03, 2010 05:42 AM
Can you get any gains with just a mild cam?
kawpower
Mr kawasaki 2 you!
posted January 03, 2010 06:54 AM
Carpenter and others bore out the buckets holes and use busa buckets for clearance with big cams,yes u can gain with mild cams with a good piston ,port and fuel setup.
Darkforce
posted January 03, 2010 09:18 AM
any opinion on tha web regrinds?
06redzx14
posted January 03, 2010 10:37 AM
when I talked to adams they said they don't even put cams in there race motors really difficult to make them worth the $$$
posted January 03, 2010 10:38 AM
That's real interesting, considering that the regrinds are under $500.
06redzx14
posted January 03, 2010 10:40 AM
+ the additional charge for the hardening($500 or so)
posted January 03, 2010 10:41 AM        Edited By: Shane661 on 3 Jan 2010 18:42
The are not showing any additional hardening costs. They aren't weld-ups.
At least that is the way I read it.
posted January 03, 2010 10:44 AM        Edited By: Shane661 on 3 Jan 2010 18:44
http://www.orientexpress.com/Kawasaki/Sport/ZX+14+Ninja/Camshafts/
Hardfaced regrind $414. Very mild cams, it seems.
kawpower
Mr kawasaki 2 you!
posted January 03, 2010 12:20 PM
believe it or not the 14s cams are pretty good thats why even to cut emmissions it has catalizers in the exhaust and it still reads rich on the dyno wich in turn reads a lower hp number but change to an aftermarket exhaust and it wakes way up so do u need cams no do u want cams its up to u.my2ct.
SteddyTeddy
posted January 03, 2010 02:37 PM
hi
That should work out to 200 to 205hp SAE.
posted January 03, 2010 02:57 PM
I would like to know the stock cam specs; it would make it easier to compare.
CajunBoyz
posted January 03, 2010 05:19 PM
Someone said a while bakc the oem cams were like 350int & 325 exh ???
LAB3
posted January 05, 2010 07:18 AM
afalk?? :-)
Louis
posted January 05, 2010 07:22 AM
As far as I know...
0.40707397460938 seconds processing time
