BIKELAND > FORUMS > ZX-14.com > Thread: New 86mm bore zx14 porting... NEW TOPIC NEW POLL POST REPLY
Y2KZX12R
CompetitionCNC.com
posted December 22, 2009 04:05 AM
As promised the new big-valve head for the zx14 is finished.
I know you guys have been waiting a long time for this head, we have been crazy busy with new development projects. But the wait was well worth it.
The zx14 finally has a cylinder head that will feed a big bore/stroke engine to its max potential. It has higher port velocity than any busa head with more CFM per sq inch than any head to date, even the famed 07 gsxr1000 head. Not an easy task.
Here's some tidbits....
1mm os valves on intake and exhaust. (needs 86mm bore or at least 85mm)
Bronze valve seats
Valve choke is increased from stage 1 and 2 head.
Higher valve window velocity over stock
MCSA increased .2 sq. in. and moved up the port .5"
Taper increased
Velocity at the MCSA was raised 10 FPS (327 fps stock)
253 CFM at .4" lift (218 cfm stock)
Chamber reworked
Stock installed spring height
Uses stock dia. buckets
Best used with our recommended custom cam grind
Needs Spring Kit and TI retainers.
I'll have some pics shortly.
Y2KZX12R
CompetitionCNC.com
wrongway
posted December 22, 2009 06:15 AM
Bronze valve seats
Taper increased
Chamber reworked
how much is flow increased ? how much hp gain with stock cam and with your cam ?
price ?
what is the lead time ? Do you need a 1530 motor to test it on ? , i can bring mine up there :-)
thanks,
Roy
WRECKSHOP
posted December 22, 2009 09:50 AM
Awesome.....Cylinder Heads will start to ROLL in Now...Watch !!! I knew you were going to do it.....Jim, you are relentless !!!!
WRECKSHOP
posted December 22, 2009 09:53 AM
So, does this solve the many issues and problems experienced with the ZX-14 cylinder head that many head porters hated it for ????
posted December 22, 2009 05:38 PM
See i told you guys and the Busa guys all that was needed is some to put the time in and the zx14 head would be a killer ...Everyone said i was full of shit ...Welllllllllllllllll I guess they were wrong ..
Thank you Jim ...You will go down in zx14 history for this one .. Let us know when all the info and pricing goes up on your website ..
Smokin ..
posted December 22, 2009 05:41 PM
Bronze valve seats
Taper increased
Chamber reworked
price ?
thanks,
Roy
Told you Roy we just needed the right guy on this head to find the power ..
posted December 22, 2009 06:58 PM        Edited By: smokinZX14 on 23 Dec 2009 03:04
Jim if you don't mind i have a question.........I'm guessing the bore needs to be one mm larger to clear the new 1 mm larger Valves ... But the place where the Valves would make contact would be at the upper most part of the bore, since the Valves are canted inward the Valve would be moving away for the sides of bore to the center of the bore ... Could we do what we have done with our big valve race motors ( car motors ) were we have had this problem and just releave the spot of contact and leave the bore stock ( 84 mm )? I know it may slow the flow a tiny bit in that area but still should flow pleanty for a stock bore motor ..I ask because a lot of guys would be willing to swap a head but may lack the funds to do a big bore at the same time as the head ..
Thanks Smokin ..
posted December 22, 2009 07:01 PM        Edited By: smokinZX14 on 23 Dec 2009 03:03
wrongway
posted December 22, 2009 07:20 PM
yeah , i want to see what gains can be expected and what the cost is.
As for notching the block , won't that cause a problem with the plating ?
Roy
posted December 22, 2009 07:21 PM        Edited By: smokinZX14 on 23 Dec 2009 03:22
Roy
Why ? The notching would be far above the rings...We are only talking 1 mm..
wrongway
posted December 22, 2009 07:51 PM
I don't know enough about the plating ... i was just worried that cutting it would leave an exposed edge that could allow the plating to seperate. on casidiam coated wrist pins, you cannot machine it after the coating has been applied.
Roy
rtbain
old, fat and slow
posted December 23, 2009 03:17 AM
It wans't my ZX. Except for the pipe its totally stock, honest.
Randy
  Ignore this member    Click here to visit rtbain's homepage.
posted December 23, 2009 07:49 PM
My Cooper head required the .050" turbo head gasket to be relieved on the exhaust side too.
1mm over stainless exhaust valves.
The stock head gasket actually is releived if you look close the cylinder bore is not round in the stock head gasket!
wrongway
posted December 23, 2009 08:47 PM
so was it just the gasket or the cylinder also ?
Roy
Y2KZX12R
CompetitionCNC.com
posted December 24, 2009 03:38 AM
With the over sized bronze seats we are able to addresses the short turn issues where there wasnt any material to work with on the outer most ports of cylinder's 1 and 4.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted December 24, 2009 03:56 AM        Edited By: Y2KZX12R on 24 Dec 2009 12:00
price ?
thanks,
Roy
Stock the zx14 head flows 218 cfm @ 327 FPS a test pressure of 28" of water on our SF600.
This head now flows 253 cfm @ 337 fps at 28".
A 1417 engine should make about 230 hp and a 1530 should make a little over 240 hp.
I suspect an all out build of a 1530 may produce 250+ hp on good fuel and 15.5 to 1 CR.
I don't think that the valves would hit a stock bore, but the shrouding of the valves will reduce the flow potential of the head somewhat.
I will put the head on a block today and check the clearance to the stock bore. A little unshrouding of the valve by sanding the bore back wouldn't be a bad idea in a stock bore application.
The nicasil can be sanded and worked with. We CNC mill block windows in the bottom of nicasil bores on a regular basis for Busas and zx12's. There can be some small slight chipping with a mill but the edges are sanded to a smooth radius removing any chipping anyway.
A sandpaper roll on a high speed die grinder wont chip the nicasil, but stones or carbide can. Just stay above the top ring.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted December 24, 2009 04:12 AM
I'll put up some pricing shortly... maybe later today... but were shutting down at noon for a shop xmas party.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted December 24, 2009 06:53 AM
Ok, I just fitted the head on the stock bore block and there's plenty of room for the 1mm o/s valves. There would be no modifications needed.
This head package has Kibblewhite1mm o/s stainless valves, APE zx14 spring/ TI retainer kit, bronze o/s seats, and a totally new design valve job ready to bolt on. $2072
The Web cams are $1,085 The cams are expensive because there's a $350 charge for hard chroming the cam journals. This is needed because the cams are thin and warp during the lobe hard face weldup process.
If you get the cams with the head package we will shim the cams for you. You will need to send us your complete head with cams.
I hope to have the web site updated shortly after the first of the year.....
Have a good xmas.
Y2KZX12R
CompetitionCNC.com
WRECKSHOP
posted December 24, 2009 09:11 AM
So, were talking roughly $3,100+ for the whole complete entire head setup ?
posted December 24, 2009 09:34 AM
Nice work Carl. Impressive!
BTW, 2 stroke dirt bikes have been running ported nicasil cylinders for 20 years now anyway.
I guess the waterjet didn't cut my gasket quite identical to the head gasket I gave them.
posted December 24, 2009 12:41 PM
That's good news Jim ... Now we can use a drop in set of 13.51 pistons with your ported head and cams .Saving money on boring and replate ....Very cool ...Later we can add the big bore or stroker ...Win Win ...
Rideharder
posted December 24, 2009 12:59 PM
Have a good xmas.
Email me @ speedaholic.net@gmail.com please..
Thanks.
  Ignore this member    Click here to visit Rideharder's homepage.
Bawls
re-learning to ride
posted December 24, 2009 01:44 PM
Hey lee... did you ever get the chance to test and see what kind of hp gains were actually made on putting the thin gasket and degreeing the stock cams?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted December 24, 2009 03:31 PM
Yes i did ..BUT it was tested at different time of the year ... With the thin head gasket and cams set at 105 107 it made the same hp as my zx14 and Tommys zx14 and any other zx14 i have run on my dyno ..If it made a difference i can't see it ...
NINJA12
posted December 24, 2009 08:55 PM
Lee with the amount of work and cost required to put pistons in the zx14, I would not do drop ins.
The only additional cost would be the bore work. Stock bore pistons cost just as much as 2mm.
Remember we have to split the cases and pull the rods, unlike the zx12s and busas.
This may not be an issue for people who does their own work, but it will be for most other who farm out the labor.
All times are America/Va [ This thread is 10 pages long: 1  2  3  4  5  6  7  8  9  -  10   Next» ] < Previous Thread     Next Thread >
0.23935413360596 seconds processing time
