BIKELAND > FORUMS > ZX-14.com > Thread: TURBO TIME NEW TOPIC NEW POLL POST REPLY
01smokes
posted December 21, 2009 06:40 PM        Edited By: 01smokes on 22 Dec 2009 02:49
TURBO TIME
i should have this thing installed and tuned by the 1st just shooting for 250hp on e85 im not even sure ill have enough injector to run e85 yet but we will see where we are and let everyone know what happens,
ill also take lots pf pics of the progress of the kit as it gets put on
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Bently
2012 14r In Blue and no Mods!
posted December 21, 2009 06:43 PM
Cool! can't wait for your results
davej
posted December 21, 2009 09:45 PM
The welds look adequate, had to redo the welds on the Muzzy exhaust and deburr the down tube. A lot of tuning had to be done to make it dead reliable. Go to You Tube and look at ZX-14 street bike at the drags. Your turbo looks small, what is it? My 1/8 mile can be beat by any ZX-6, launch is terrible but top end is awesome.
Triumph guy
Bawls
re-learning to ride
posted December 21, 2009 10:41 PM
YUCK! I believe I'll pass lol
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Superman T
posted December 21, 2009 11:44 PM
Good luck smokes! Can't wait to see how it turns out..
NinjaNick
'08 ZX14 (Blue)
posted December 22, 2009 09:34 AM
hell yeah! godbless turbos!
duncan
posted December 22, 2009 11:54 AM
{FAIR WARNING} Once you taste boost theres no going back.
Big_T112
posted December 22, 2009 07:16 PM
That turbo system in the pic made 390 Rear wheel H.P. at 16 lbs of boost. We were using RC 550 injectors.
Bawls
re-learning to ride
posted December 22, 2009 07:29 PM
he's in NM though... I think his 14 is putting down mid 130's right now.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
01smokes
posted December 22, 2009 09:54 PM
yep last time it was on the dyno it put down 133 actual HP and 162 corrected HP i sure hope to bring them numbers up by about 130hp in the next couple weeks we shall see what happens.
i was just debating on a fuel system and i think i figured it out, im going to go with 1000cc injectors a regulator and and a bigger fuel rail its going to always be ran on e85 and that takes about 30% more fuel than gas, and everyone that i know that has ran the e85 on boosted applications ALWAYS pick up 30-50HP over fuel with the same boost levels, but the cars are all in the 700-900hp range.
Compton
posted December 23, 2009 05:57 AM
if you like street riding your bike those 1000cc injectors may not be the best choice.
b.w.
01smokes
posted December 23, 2009 02:32 PM
I was wondering about that, im not sure how low ill be able to take them and still keep them streetable, i could afford to lose some streetability but i need to ride it some times on the street
01smokes
posted December 23, 2009 02:45 PM
here is a injector calculator
http://www.fusion-d.net/injcalc/index.php
Big_T112
posted December 23, 2009 04:34 PM
You do know that the FMU you got with the kit is a Boost compenstaed regulator? It has static and on boost adjustability. the static is set just like any regulator with the lock nut and the screw. the boost is adjusted by the small valve on the top. It basically bleeds boost off through that valve. As the bike makes boost it puts pressure on the top of the regulator making the fuel pressure go up which richens the bike up. It's simple and works very well. Plus it will be a great daily driver.
0.26560711860657 seconds processing time
