BIKELAND > FORUMS > ZX-14.com > Thread: Need help wiring LED shift light.... NEW TOPIC NEW POLL POST REPLY
Nbrion
posted December 04, 2009 09:13 PM
I need some direction on how to wire a LED flashlight to use as a shift light. I know it can be done, but need you guys help! I was thinking I need to run a resistor to reduce from 12v to 5v, but not really sure. I’ll hook the other wires to a relay and have the power commander multi hub control the shift points.
Bawls
re-learning to ride
posted December 05, 2009 05:53 AM
you might be a redneck if...
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
kawasakijockey
posted December 05, 2009 06:20 AM
Works perfectly fine. I have the same setup. The hub output wires are negatives. Dont wire the negative directly to the light, use a relay. If you wire directly to it, it will flicker the light at certain times or rpm for no explainable reason. Dynojet is aware of the problem.
On the relay attach a 12v+ wire to terminal 86 with a jumper to 30. Attach the w/g output wire of the hub to 85. The 12v+ wire of your LED goes to 87 and the 12v- wire goes to a frame ground.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted December 05, 2009 08:01 AM
Just a shift light dosent cost that much does it?
Nbrion
posted December 05, 2009 08:29 AM
Kawaskijockey, The neg can go to the battery or the frame... right? Let me know if this looks right. If so, I will try this today or tomorrow.
kawasakijockey
posted December 05, 2009 09:32 AM        Edited By: kawasakijockey on 5 Dec 2009 17:39
Incorrect. The battery ground does not join to the w/g wire to the 85. The LED neg needs the frame or battery ground. The rest is correct. Redraw and post it again.
I cant host pictures to the web so I cant redo it for you or show you a pic of an alternative shiftlight that works well. Autozone sells the Pilot Hyper Blue CZ-2958 LED accent light for around $15. There are 2 in the package and each has 3 led bulbs that are very bright. All you need is one of the two and it mounts perfectly on top of the guage cluster with the double sided tape.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Nbrion
posted December 05, 2009 09:53 AM
Thanks for your help! Whats your email so I can send it to you directly. or email me neilbriones at att dot net
kawasakijockey
posted December 05, 2009 10:06 AM
Be sure to post your corrected diagram here as it can help someone else in the future.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.22499585151672 seconds processing time
