dcjens
Wet side of Washington
posted November 30, 2009 05:16 PM
Muzzy M14 M10
I'm hoping to find out more about this setup. I have a full system, stainless header, aluminum round canister.It's called a full race from 58cycle. Ive never seen this called an M14 anywhere. I've heard of the "old style" and wondering if I have that. I want to put the M10 meg on it end result (before I get out the sawzall) I've contacted Muzzy but wanted to hear if somebody knows about this here.
Black 06
biker
HU$TLER
posted November 30, 2009 10:37 PM
The M14 is the old style and M10 is newer and LOUDER. I have the M10 and its very nice,the meg does make a difference.M10 is much shorter than the M14 as well...
SEIZED...REBUILDING HOT ROD TIME
Bawls
re-learning to ride
posted November 30, 2009 10:44 PM
Correction... The M14 is the new style header with larger primaries. the old style muzzy didn't make near the power of the m14. The M10 is the small meg that you want and you should be able to get it for which ever header you have. My dad was running the old header with the m10 muffler but just bought shane's short meg.
if you want to see what the M-14 header looks like, go check out shane's build thread.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
dcjens
posted December 01, 2009 12:37 AM
thanks Bawls.. I looked at that. My meg doesnt have the strap around the canister. It has a welded triangle on the back that goes directly to the passenger peg. How long ago was the OLD style available? I bought this a year an a half ago, new. damn the M10 is as much $ as a whole pipe! I found Shane's new Brock's pipe too.. That's what started this new itch. My full length meg is starting to look like the stock long ass muffler.
Black 06
68gts2
hobbies ( Beating you !!! )
posted December 01, 2009 04:50 AM
Dcjens look at your head pipe about 4 inches after where it bolts to your head. If it has a tapered step about 3 inches long with 2 welds to conect it its a m14. If it is a pipe slid on to the smaler headpipe with only 1 weld its the old style step header. The diderent mounts on the cans are just that different cans available from muzzy. Shane started with the stainless can and it sounds like you have the aluminum can,same as I do. That m10 can looks tastyanbut be aware its fuin loud.
dcjens
posted December 01, 2009 06:47 AM
68gts2- There's only 1 weld 4" down, no taper. small size out of header, then larger all the way down and under. Thanks, that's what I was looking for!
Black 06
68gts2
posted December 01, 2009 07:26 AM
Is it time for jcjens to step up to a new m14 with a m10 can? I don't know about the m10 option,but I got my m14 with aluminum can from lyn at starcycle.com for about 650 bucks to the door,and that was last year when it was hot so price may have droped some.
LAB3
posted December 01, 2009 07:32 PM
There are two different M10 Megs. The old style M10 system Meg will not fit the
tapered head pipe M14 system. The M14 has a larger dia. collector than a older M10 headers.
So be careful on purchaseing a M10 Meg for your Muzzy head pipes. I have Shane's
M14 system and looked at a new M10 Meg ........to much $$ for 2 HP. Polished Stainless
oval silencer has starp to rear footpeg. Also a M14 tapered head pipe has a O2 bung for Data Log A/F the old M10 head pipes did not have.
Louis
posted December 01, 2009 07:33 PM
BROCKS FTW
dcjens
posted December 01, 2009 09:16 PM
My header has the 02 bung. Everybody replying so far has a much better answer than Muzzy did. what the heck? They said I had the "standard pipe" for a ZX14. standard new or old? The m10 to fit mine is a pretty good chunk of change for an "old " system. I got my whole current system for less than 6 bills delivered. I'm going to have to think about this now...thanks Steve
Black 06
epd345
posted December 01, 2009 10:00 PM
Ya I couldn't pass up a full Yoshi TRC stainless 4into1 with titanium can......for $505 to my door directly from Yosh
01smokes
posted December 01, 2009 10:17 PM
il be selling my m14/m10 at the end of the year ill make you a killer deal on it than
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
dcjens
posted December 01, 2009 10:27 PM
01smokes email me about that dcjens@yahoo.com
Black 06
