BIKELAND > FORUMS > ZX-14.com > Thread: ok School time NEW TOPIC NEW POLL POST REPLY
1badzx12r
posted November 24, 2009 07:20 PM        Edited By: 1badzx12r on 25 Nov 2009 03:22
ok School time
where is #1 cylinder on a zx14 .. i've seen to mis-placed it and can't find it..
and on a 2nd note the rubber washers on the injectors that contact the throttle bodies is suspect to vacum leaks .. or in my case boost leak..
and who is running heavy valve springs and not having issues keeping the valves adjusted
posted November 24, 2009 07:35 PM
1 seated on the bike number one is on the left
2 Yes they could leak boost but would have to be in real real bad shape to do so .
3 That i have no clue about , i have never run the HD springs ..
1badzx12r
posted November 24, 2009 07:51 PM
quote]
oh no can't be there.. i looked there
posted November 24, 2009 07:52 PM
quote]
1badzx12r
posted November 24, 2009 07:59 PM
..i've owned the bike almost 4 years and just found #1 cylinder yesterday
posted November 24, 2009 08:05 PM
I have to ask .... Now that you found it what the hell you going to do with it ? lol...
1badzx12r
posted November 24, 2009 08:11 PM
i have no clue .. i'm still in a state of shock ..
INTIMIDA2OR
RED rider!
posted November 24, 2009 08:42 PM
And to think you have 3 more cylinders
'06 Passion Red ZX-14
*Lee*
ZX11D
Internet Police
posted November 24, 2009 09:30 PM
Now............where exactly did you find this cylinder?
'94 ZX-11
'07 ZX-14
Douglas Home
posted November 24, 2009 10:55 PM
What is a TRE ? Does it have leaves?
Doug Mackay Australia
INTIMIDA2OR
RED rider!
posted November 24, 2009 11:13 PM
I think it's a doodad that sits on top of a whatnot
*Lee*
Douglas Home
posted November 24, 2009 11:47 PM
I'll have two , black thanks.
1badzx12r
posted November 25, 2009 04:37 AM        Edited By: 1badzx12r on 25 Nov 2009 12:38
i found it in the service manual under valve adjustments .. when you prepare the bike with TDC#1&4 to the rear engine cases and the cam makings to the outside of the head .. number 1 cylinder is then next to the cam chain .. cause you can not gauge the far cylinder that's know as #1 on the far left .. unless you roll the motor 180 an the cams then roll 180 thus putting the cam marks facing each other on the inside of the head..which in turn puts the cylinder on the far left known as #1 as sitting on bike on TDC .
Manual explains it but even it is wrong with the way the pic has which valves to check on TDC ..Cause pic shows from the left as #1 ..but when you have the crank trigger on TDC#1&4 to the rear of cases as manual says you can not feeler gauge those cylinders in that pic..
i use to pay to have my valves adjusted on my zx14 (twice) and never did them .. but since putting the heavy springs in and a valve job and set to factory spec's ..i can't keep them adjusted ..either i'm pounding my seats into the head or the valve stems are stretching .. cause twice now after 4 passes i lost compression and after leak down found tight valves the case..order a shim kit yesterday ..
posted November 25, 2009 05:42 AM
Sounds like to me you would be money ahead to pay someone to do it.
1badzx12r
posted November 25, 2009 08:06 AM
AND why you say that ... do you know where #1 is ..if not go look in the manual and find out ..
Hurricane
posted November 25, 2009 08:13 AM
I usually lose #2 and #1 at the same time!
1badzx12r
posted November 25, 2009 08:19 AM
i'm losing #1&4 ..done added .002 to #1 exhaust valves .. and .001 to the intake on #4 in 2 valve adjustments in 8 total passes ..
i'm gonna set them all on the loose this time at .007 IN and .011 EX .. And see what happens
INTIMIDA2OR
RED rider!
posted November 25, 2009 12:03 PM
Ouch! Well if they tighten up again that means you need to find where the clearence is going! Either the valves are going, or the seats are getting pounded.
What's the seat pressure?
*Lee*
posted November 25, 2009 01:16 PM
I know you had the head off recently, did you have a valve job done? sometimes they will cut the seats slightly different angles to make sure they seal right off the bat(the better guys dont need to do this) after awhile the valve and seat will sort of smash themselves together enough to deform the seat to be the same angle and then you get the normal valve seat contact patch instead of a thin one. doing so results in less clearance. i reserve the right to be wrong...
1badzx12r
posted November 25, 2009 04:24 PM
yes scott ..i had a valve job do at the machine shop ..then after blowing a head gasket i found several tight valves ..now after a fuel pump failure i checked again and found some of the same valves tight again .. anytime i've got to pull fairings i do a compression check.. then a leakdown test if my compression is low ..
Bad in Black
posted November 25, 2009 04:52 PM
Rob you've been turning the boost up again haven't you lol.
1badzx12r
posted November 25, 2009 05:27 PM
nope.. can't keep it running long enough to do any boost turning up ..
zxbob
posted November 26, 2009 08:42 AM
You should get the head ported . . . . . . . I hear on a turbo they flow liquid aluminum better
than a NA motor does.
Bob
1badzx12r
posted November 26, 2009 11:45 AM
Bob
thats a fact. ..but i hear N/A Likes case iron
posted November 26, 2009 11:50 AM        Edited By: Shane661 on 26 Nov 2009 19:52
What is your seat pressure with your valve springs??
0.24059700965881 seconds processing time
