BIKELAND > FORUMS > ZX-14.com > Thread: fuel pressure NEW TOPIC NEW POLL POST REPLY
Big_T112
posted November 21, 2009 12:51 PM        Edited By: Big_T112 on 21 Nov 2009 20:57
fuel pressure
The BEGI uses a boost signal to add pressure as the boost rises. Say you have 40 lbs normal off boost. As you add boost the signal hose which is adjustable adds pressure by putting boost on top of the regulator. say at 12 lbs of boost you may see 90 lbs of pressure on the gauge under boost. This all needs to be tuned on the dyno. This is on a Turbo 14 with an external pump. Lean on a turbo is not good.
0.21545195579529 seconds processing time
