BIKELAND > FORUMS > ZX-14.com > Thread: Oil Cooler NEW TOPIC NEW POLL POST REPLY
14nooby
posted November 18, 2009 04:01 PM
Oil Cooler
Any benefit in removing the oil cooler and just connecting the lines? I have seen several bikes without it and just wondered why remove it. I would assume on a drag only bike it is not needed.
posted November 18, 2009 04:03 PM        Edited By: Shane661 on 19 Nov 2009 00:03
I've been considering the same thing, Chad. Maybe I'll look at it tomorrow. If I do, I'll be sure to weigh it as well.
For the street it doesn't seem like a good idea.
14nooby
posted November 18, 2009 04:08 PM
Thanks, I was hoping you would chime in.
ninjaboy311
posted November 18, 2009 04:38 PM
Mine is gone from installing the Adams pan. I didn't notice any difference.
14nooby
posted November 18, 2009 04:56 PM
Ninja, did you connect the two hoses with a splice or what did you do?
posted November 18, 2009 04:59 PM
Here some info on doing the same on a Busa:
http://www.suzukihayabusa.org/forum/index.php?topic=111661.0
I'm not sure if the 14 has a flow restrictor such as the one on the Busa? That might be important to know.
INTIMIDA2OR
RED rider!
posted November 18, 2009 06:34 PM
Interesting
'06 Passion Red ZX-14
*Lee*
1badvespa1400cc
power junkie
posted November 19, 2009 01:33 PM
Well what's up????
Just another foeteen!!!!!
INTIMIDA2OR
RED rider!
posted November 19, 2009 01:51 PM
*Lee*
posted November 19, 2009 02:21 PM
Clearly you guys are unclear on what a "maybe" is.
ninjaboy311
posted November 19, 2009 02:42 PM
I installed a small length piece of stainless tubing between the 2 hoses, installed hose clamps, and thats all I did. The coolant just flows through the hose continuously as if the cooler was still there.
posted November 19, 2009 02:54 PM
Mines is staying right where it is ...
INTIMIDA2OR
RED rider!
posted November 19, 2009 05:14 PM
I'm with you on that!
*Lee*
gilberjj
Friend of Fast
posted November 19, 2009 05:22 PM
+2
dcjens
Wet side of Washington
posted November 19, 2009 06:58 PM
"If it isn't broke, don't fix it"
Black 06
posted November 19, 2009 07:07 PM
leave it on. it helps get the oil up to operating temps when you start a cold bike as the coolant heats up a lot quicker than the oil
INTIMIDA2OR
RED rider!
posted November 19, 2009 10:01 PM
+1
*Lee*
posted November 20, 2009 04:44 AM
Ride mine on the street too much for all that.
posted November 20, 2009 04:56 AM
I believe that it is recommended to run the 2" billet pan on the street, as opposed to the 1 1/2"...since the oil cooler is gone with that setup. I guess a little extra oil volume helps.
0.39436388015747 seconds processing time
